Oct 09, 2009, 07:34 PM
Dave Fritzke Ace Pacer wing ?
This (plans) has a built up wing (kit had foam wing). Any suggestions on how to
shim up the tapered wing to come out like the foam wing ?
Oct 09, 2009, 09:59 PM
Andrew0820's Avatar
One technique in building this type of wing is to build it upside down. This will give the appearance (and effect) of having a slight dihedral. Since the ribs do not have tabs, you will need to use blocks along the TE to keep from building in washout or washin.
Draw a line running from the center of the front of the rib to the center of end of the rib -- a chord line. Ideally, the chord line would run from the center of the LE to the tip of the TE. If you're using the Gene Rock's CAD drawing from Dave Fritzke's site, the LE and TE are shown for ribs 1 and 9. You can fill in the locations for 2 thru 8.
Draw a second line parallel to the first and tangent to the top of the rib (if you are going to build upside down). The vertical distance from the top line to the top of the TE spar will give the shim height for each rib.
I've attached a pic, but I don't know how viewable it will be.
andrew
Oct 10, 2009, 03:44 AM
Thanks Andrew
Oct 16, 2009, 01:55 PM
Check out this build thread.
http://www.rcuniverse.com/forum/m_8169709/tm.htm
WTB ACE Pacer 20 KIT Dadzilla-5 Aircraft - Fuel - Airplanes (FS/W) 3 Apr 03, 2004 03:14 PM
Ace Foam wing project....power advice needed mrtim Power Systems 3 Mar 07, 2002 04:05 PM
Any interest in an Ace Pacer conversion review? ZAGIZAGI Sport Planes 41 Mar 04, 2002 07:57 AM
Electrifying the Ace Pacer (Link to Huge Photo Essay) ZAGIZAGI Sport Planes 0 Feb 24, 2002 05:03 PM
Electrifying the Ace Pacer (Link to Huge Photo Essay) ZAGIZAGI Electric Plane Talk 0 Feb 24, 2002 05:02 PM
