This thread is privately moderated by jackerbes, who may elect to delete unwanted replies.
Nov 07, 2019, 02:28 AM
davereap's Avatar
the gartt 2204 motors are stronger than the sunnysky, they have similar power, will run on 2s or 3s, but are more impact resistant..
In our indoor crash and bash sessions the sunnysky get bent out of shape..
Nov 07, 2019, 12:17 PM
flyin' fool
goldguy's Avatar
The Gartt motors are easy to take apart and clean if you get trash inside. The Sunnysky is not!!!
Nov 07, 2019, 02:41 PM
scratchbuilder
Thomas B.'s Avatar
Frank, the Jupiter Bee has the Jupiter Shrimp wing with slighly changed shape, KFm 4 and no dihedral. Span is 64cm.
Here are some KF birds with aggressive behaviour.
Fighting birds (2 min 11 sec)
Nov 07, 2019, 04:38 PM
looking up, down under
scruffy1's Avatar
thanks for the heads up
added to my wish list as an alternate source
Nov 27, 2019, 09:44 AM
davereap's Avatar
My Latest KFm4... is A conversion of my big PP1 made into a Quasar v2..
This is a 30" span lump.. with an AUW of 33.2oz and a 7 ozsqft wing loading
Made for outside in the wind
this video is from the KFm4 PP1 flight, I will get some video when it stops p-ing down
PP1 KFm4 with 3536 and 11x7SF prop on 3s 2200 flt3 23 04 2015 (10 min 33 sec)
Nov 28, 2019, 03:08 PM
scratchbuilder
Thomas B.'s Avatar
What a great stable flyer!
Dec 02, 2019, 06:36 AM
davereap's Avatar
Ive been working on a STOL model.. After looking at the many good bush type models being sold.. funcub, timber, tundra etc.. and loving their performances, but not liking the prices too much.. The funcub kit is about 100... my preferred model is the Timber X 1.2m but this only comes fully loaded and is 224 PNP or 250 BNF with safe.
I have been designing my own KFm3 build.. So far the wing is laminated, but there remains a lot to do..
6mm is depron being used with a lot of doubled layers for strength.
Span is 52"... chord 11"..
The made up spar is cut into layer 2 and glued in place , with the two step layers fixing it firmly in place
edit..
Wing almost done, it only needs the servos fitted
Dec 02, 2019, 04:03 PM
"long stretch of water..."
coongoola's Avatar
Originally Posted by davereap
Ive been working on a STOL model.. After looking at the many good bush type models being sold.. funcub, timber, tundra etc.. and loving their performances, but not liking the prices too much.. I have been designing my own KFm3 build.. So far the wing is laminated, but there remains a lot to do..
Looking forward to this one Dave. A bit different to the deltas you've been building.
I'll wait and see how yours maidens. 😊
Pat
Dec 04, 2019, 01:12 AM
davereap's Avatar
Working on a fuzz..the sketchup drawing sizes are being modified as I build..
Its construction is built around a central full length spline, 2x6mm layers thick.. the original sides were not a pleasant shape, it was looking too big and boxy, so these are being reduced bit by bit..until it looks ok..all TLAR..
Then after I get it looking better, there will be doublers going internal to make it all a lot stronger..
Dec 04, 2019, 06:50 AM
scratchbuilder
Thomas B.'s Avatar
I am looking forward to seeing it fly. Very interesting project!
Dec 04, 2019, 10:50 AM
davereap's Avatar
Its taking me ages.. but the internal doublers are all in place, plus some bottom fuzz sheeting with some rounding at the edges...
normally my simple models are all done in one day..
Ive left a lot of decking off , to make it easier to fit the motor , push rods and other internals
Dec 04, 2019, 07:26 PM
scruffy1's Avatar
can i suggest using a technique i have "invented" but not yet used ?
for the leading edges of the tail feathers, you can iron on a folded piece of laminating sheet - the stuff of heat laminate pouches - so as to strengthen and streamline the section's entry
my current practice is to sand the foil for the wing leading edge, but then to iron it with a sealing iron (carefully) and it hardens the surface making it more impact resistant and less porous - but on a straight section the laminate dies great; i used it on my bonzai and it added considerable rigidity and strength for hardly any weight
Dec 05, 2019, 11:52 AM
davereap's Avatar
People have been using laminating film for ages, .. All my KF slope gliders are now skinned with depron followed by laminating film all over..
This improves the glide speed
Dec 05, 2019, 03:44 PM
flyin' fool
goldguy's Avatar
The wheel has already been invented.
GPW came up with the idea back in 07' about using heat on foam ……………… https://www.rcgroups.com/forums/show...&postcount=313
I've been ironing all types of foam and using laminating film for ages.
Dec 05, 2019, 04:30 PM
scruffy1's Avatar
well, i invented them both last then
Discussion ** Kline-Fogleman Airfoiled Flying Wing ** Tony65x55 Foamies (Scratchbuilt) 3960 Jul 20, 2018 06:01 AM
Idea 40" Depron Dynamite, Kline fogleman Depron build dougmontgomery Hand Launch 693 Jul 11, 2017 09:48 PM
Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) dougmontgomery Foamies (Scratchbuilt) 151 Apr 21, 2014 09:08 AM
Video Kline Fogleman Airfoil on a flying wing Tony65x55 Electric Plane Talk 3 Jan 30, 2009 08:37 PM
Discussion Kline-Fogleman Airfoil on a flying wing Tony65x55 Modeling Science 1 Aug 20, 2006 11:14 AM
