This thread is privately moderated by jackerbes, who may elect to delete unwanted replies.
Jun 29, 2019, 08:18 PM
Jack
jackerbes's Avatar
It sounds like you are off on a project that could prove very useful and interesting.
You could use another pair of servos or a single servo and use a portion of the the foam at one of the steps as spoilers.
Here is the actual dimensions that worked for me on the KFm9.
Jack
Jul 06, 2019, 09:34 AM
amj
amj
When tip chord = 0 ?
I'd like to build something this shape, that has a true triangular form (i.e. wing tips coming to a point - not truncated):
Delta RC plane (2 min 1 sec)
For a KFm-2 or KFm-4 wing, where should the step run out at the wing tip where the chord goes to zero?
Can you see any problem running the step from (say) 50% at the root chord all the way out to the pointed tip?
Adrian
Jul 06, 2019, 09:39 AM
Gregco10's Avatar
Description:
This works great if that helps. The step ends at the hinge.
Edit: I just watched that video, if you want nice low speed maneuverability build the FT Vector, build it it really light with a light setup. It will have excellent low speed high alpha plodding around capability. It has a low mounted rudder just for that type of flying.
Jul 06, 2019, 02:09 PM
flyin' fool
goldguy's Avatar
Like this? https://www.rcgroups.com/forums/show...lta-Wing-Build
There's a lot of similar designs in the plans list.
Jul 07, 2019, 04:55 AM
Reap the wild wind
headlessagain's Avatar
I made a couple of KFm puller deltas. The first was from EPP and the second from Depron. Both flew very well being quiet and aerobatic.
EPP RC Flying Wing (3 min 12 sec)
Andy
Discussion ** Kline-Fogleman Airfoiled Flying Wing ** Tony65x55 Foamies (Scratchbuilt) 3960 Jul 20, 2018 06:01 AM
Idea 40" Depron Dynamite, Kline fogleman Depron build dougmontgomery Hand Launch 693 Jul 11, 2017 09:48 PM
Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) dougmontgomery Foamies (Scratchbuilt) 151 Apr 21, 2014 09:08 AM
Video Kline Fogleman Airfoil on a flying wing Tony65x55 Electric Plane Talk 3 Jan 30, 2009 08:37 PM
Discussion Kline-Fogleman Airfoil on a flying wing Tony65x55 Modeling Science 1 Aug 20, 2006 11:14 AM
