Sep 24, 2009, 04:51 PM
Nine Eagles Kestrel/Free Spirit FP question
Trying to figure out my problems...the heli hasn't been modded, and all of the sudden it's acting "squirrelly" and has zero forward flight.
Only thing I can figure out is my swash a tiny bit of slop...not separated totally, but a teeny bit of slop...could this be my problem?
Thanks in advance!
Sep 24, 2009, 05:01 PM
CQE Flash's Avatar
Thanks in advance!
More than likely.. Any slop and the head will oscillate and become unstable. Not sure if your heli uses feather shaft dampers ( o rings and the like ) if they are missing or damaged that can cause it to become unstable.
just guess really as I don't have your heli - sorry.
Flash
Sep 25, 2009, 02:41 PM
Thanks for the help!
Oct 04, 2009, 09:42 PM
Stumblebee's Avatar
Sorry to be coming in a bit late on this one. I found that by replacing the swash on my Nine Eagle Free Spirit FP with the metal swash from the CX2, the problems with slop disappeared. If you decide to do this, you will also have to pick up the CX2 linkage rods. The balls on the CX2 swash are smaller than the balls on the Nine Eagles swash. You also might want to check that the swash arms are not coming in contact with the fuselage body. I find that I have to double check mine before each flight because the fuselage does slide back and forth on the upper support rod.
Discussion Nine Eagles Kestrel 500SX RC Hobby Helicopter Modding Thread johnIn2SonAZ Micro Helis 902 Feb 02, 2013 04:28 AM
Discussion Blade MCX vs. Nine Eagles Solo/Free Spirit PicooMan Coaxial Helicopters 28 Oct 17, 2010 04:44 PM
Sold (2) Nine Eagles Kestrel 500sx FP Heli AtTheCross Aircraft - Electric - Helis (FS/W) 3 May 15, 2009 05:15 PM
Discussion Nine Eagles Kestrel Free Spirit... MConstable Coaxial Helicopters 6 May 14, 2009 10:22 PM
Discussion Nine Eagles Kestrel (Hughes 500) Coming? rbinc Coaxial Helicopters 37 Jan 28, 2009 04:36 PM
