Help!
Mounting prop on slow stick
What is the proper way to mount the prop on a slow stick?The motor shaft seams to be oversize.Is the prop screwed on to the motor shaft?This is the prop that came with it.
If you have a stock 400 geared motor (black gear case) and they sent slow fly props in the box, you will have to ream them out or use a drill to make the prop hole larger. I think the shaft on the GWS gear box is a 4mm if I remember right.
Hope this is your question?????????? Happy Flying Bob |
Slow stick prop mountingQuote:
Just get a 4mm prop saver easier to set up and it will save you money from broke props. I can tell you it will pay for itself the first bad landing.
Thread Tools | |
Similar Threads | |||||
Discussion | Max size prop on Slow Stick | aspencer80 | Electric Plane Talk | 6 | Mar 28, 2006 02:27 PM |
Folding Prop on Slow Stick? | rutat | Beginner Training Area (Aircraft-Electric) | 1 | Nov 19, 2004 04:02 PM | |
Question | Question: Folding Prop On Slow Stick? | Sparrowhawk | Aerial Photography | 2 | Jul 08, 2004 11:34 AM |
EPS-400C + Prop combination on slow stick? | Hasina75 | Beginner Training Area (Aircraft-Electric) | 23 | May 08, 2004 08:48 AM | |
EPS 400C ratio and the right prop on Slow Stick? | Hasina75 | Electric Power Systems | 0 | May 03, 2004 04:58 PM |
