Sep 09, 2019, 03:26 PM
Electric baptism 1975
DavidN's Avatar
I am using 5,000mah.
I shaved the servo tray back to the former so the battery can go back further. Tail weight recommended. Moving servos back to in front of wing trailing edge helps & is easy. Moving them behind the trailing edge eliminates tail weight. Nose heavy males it hard to slow down. I use a landing flight mode with 3 clicks of uptrim.
Sep 09, 2019, 04:53 PM
Hi David, Is that 4 or 5s 5000mah Pack?
Sep 09, 2019, 05:39 PM
DavidN's Avatar
4s.
Sep 10, 2019, 10:59 AM
jrb
jrb
Member
jrb's Avatar
My A123-6S is well aft to get CG correct.
I also use a little spoileron to get a bit more sink rate on landing.
Sep 10, 2019, 11:01 AM
I hate that they stopped making this one.
Sep 10, 2019, 11:05 AM
DavidN's Avatar
Maybe there is a foam incarnation in the future.
Sep 10, 2019, 11:13 AM
It just wouldn't be the same.
Sep 10, 2019, 11:23 AM
DavidN's Avatar
HH says they sell better
Apr 24, 2020, 09:59 PM
DavidN's Avatar
Took my trusty TS out to the field today and noticed an extra wire from the wing. I realized I had brought the wing from the new plane which has the remote receiver in the wing. Fitted it onto the original fuselage. It fit perfectly. I took off and ailerons were centered. No problems.The ARF is obviously well-crafted.
Sep 11, 2020, 09:19 AM
Gravity Sucks
Is there any easier solution like a thumb screw or something to get access to the battery? Once you take the little screw out the door does not want to come off. I was thinking that maybe some sort of thumb screw like they use on the canopy hatch on boats might be an option?
Sep 11, 2020, 11:23 AM
DavidN's Avatar
The battery hatches strong magnets to hold in place, the screws are for the glow option. The hatch has a wood cut out covered with blue film. If you cut out the air hole in the hatch it is easy to hook the hatch off with a finger in the hole.
Feb 19, 2022, 01:10 PM
I'm looking to purchase the next aircraft of this type
Hello friends
Hangar 9 Toledo Special 40-50 ARF
Does anyone happen to have the plane.
And interested in selling
Contact me
avisha1963@gmail.com
Discussion Hangar 9 Toledo special terrabit2001 Electric Plane Talk 30 Sep 30, 2009 08:42 AM
Horizon Hobby's Hangar 9 Showtime 3D ARF Review Steve H. Fuel Plane Talk 5 Sep 01, 2007 05:59 PM
Horizon Hangar 9 Twist 40 ARF AMCross Product Announcements 0 Apr 30, 2004 08:09 PM
