This thread is privately moderated by Prof100, who may elect to delete unwanted replies.
Sep 19, 2009, 08:06 PM
Prof100's Avatar
Rules for determining plane dimensions
SAVE this post regarding rules of thumb for plane dimensions.
Originally Posted by Vantasstic
On the note of EZ Glider wings on the EZ*. There's been much talk of turning problems, ineffective rudder, needing lots of coordinated rudder, etc. Many years ago (1998 to be exact) I developed a R/C Design calculator using Excel. It's rather crude by today's standards, but proved very useful to several folks as I've found it on websites from the U.S. to Russia. Anyway...in the research I did to develop the spreadsheet I found some 'average' rules of wing vs fuse vs empenage size comparisons. In short, for the plane's wing the following are the 'average' sizes of the other components:
Horizontal Stab: 20%-25% of the wing area
Elevator: 20%-25% of the horizontal stab chord
Vertical Stab: 7%-12% of the wing area
Rudder: 30%-50% of the vertical stab chord
Fuse Length: 70% of wing span (measured from nost/thrust washer to rudder hinge line).
By putting the EZ Glider wing on the EZ* you've 'messed' up the 'average' design parameters, thus have to make necessary adjustments...as most have reported...a larger vertical stab and rudder.
edit:
A ZIP file of my calculator is attached for those who are curious. Some of the pictures might looked goofed up in some versions of Excel, but the formulas should work correctly.
Excellent. You answered my question regarding how long to make the fuselage.
May 14, 2012, 10:31 AM
Balsa builder and balsa basher
RC Trainer plane's Avatar
Thanks this is really helping my scratch build .
May 14, 2012, 10:59 AM
Prof100's Avatar
Great. Let's see some pictures.
May 14, 2012, 11:01 AM
You ok with me posting them here if not here the link to my build https://www.rcgroups.com/forums/show....php?t=1638287
May 14, 2012, 11:02 AM
Prof100's Avatar
Sure
May 14, 2012, 11:05 AM
There's quite a few so here's the link to my build instead https://www.rcgroups.com/forums/show....php?t=1638287
Also here's a question my plane wingspan is 1.6m so what should the lengths be for my rudder and elevator ?? All this area stuff is confusing me
May 14, 2012, 12:15 PM
Prof100's Avatar
Assuming you know the differenece between the horizontal and vertical component it's in the first post:
May 14, 2012, 12:19 PM
Sorry about that asking someone else to do my own work . Don't worry thanks for the help again I'll just have to figure it out ? You should check out my build
Thanks again
May 14, 2012, 12:23 PM
Prof100's Avatar
Thanks again
I did check out your build. You are very good at it and will do well. Make sure you fly with a Simulator first. Googe FMS and buy a $20 4 channel controller. FMS is free. Practice flying until you don't crash.
May 14, 2012, 12:26 PM
Thanks for the help mate your a real helpful person , what do transmitter do you think I should get I'm not quite sure whether I should get a really cheap transmitter that I've never heard of before but seems good or splash the cash that I don't have on a really expensive transmitter
May 14, 2012, 12:30 PM
Prof100's Avatar
I use Spektrum radios but they are pricey. Many people rave about $60 ghz radios you can buy from Hobbyking. They are reported as reliable and receivers are very inexpensive.
May 14, 2012, 12:32 PM
I've looked at spektrum before and the brand was at the top of my list. I suppose if I want to get into rc the proper way I might as well splash the cash
May 14, 2012, 12:37 PM
Prof100's Avatar
It all depends on your budget.
May 14, 2012, 12:40 PM
I have about 50 or in dollars $ 80 for a transmitter and a receiver. For the servos I have about 5 for each.
May 14, 2012, 12:49 PM
Prof100's Avatar
Your budget is ideal for Turnigy 9x. Servos you can use are HXT900 or better.
Go the radio forum and ask questions there. I have no other knowledge other than favorable reports by fellow RCgroup member regardin that radio.
Discussion determining the right CG for this plane Florin777 Modeling Science 4 Feb 09, 2006 06:03 PM
Rules for determining size of lion pakc (XsyP) byrocat Batteries and Chargers 2 Dec 03, 2004 12:46 PM
===== WANT recommendations for first plane ===== Kolchak Beginner Training Area (Aircraft-Electric) 30 Jun 06, 2001 06:20 AM
Wattage Hawk for first plane. austin9000 Beginner Training Area (Aircraft-Electric) 3 May 16, 2001 06:19 AM
Wattage Sporty for second plane newbie? 177ichael Beginner Training Area (Aircraft-Electric) 5 May 09, 2001 04:51 PM
