Apr 19, 2003, 05:39 PM
TeamZiering
enigmabomb's Avatar
Miniflash Saga Continues - Tail Heavy
So, It's been really nice here these past few days. I have been flying, and preparing my miniflash to go again. So, Today, I decided to maiden it with GWS gear. It still remained tail heavy, so much so I had to add 3 AAA batteries to the nose just to get it to balance within acceptable limits. I had the batteries and Reciever as far as they would go. It flew, but lumbered along not a foot off the ground, i couldn't even make a circle to come back to me, I ditched in the grass. At this point, I put my 7 cell nicads in and took off the batteries. It flew, but still was extremely tail heavy. I ended up crunching it up really good. Again. This is the fourth time, I must be doing something wrong. How can I get this to balance right?!
-Josh-
Setup:
Solite covering
Built with Thin CA
8 Cell 720 Nimh
GWS 300c-D Gearing
12 inch GWS prop (12x6)
20 Amp GP Speed Control
8 Channel Reciever
Hs 55 Servos.
(I had a hacker in it before, but that wouldn't balance either, and the gear boxes were getting too expensive)
Apr 19, 2003, 06:10 PM
Been There! Done That!
boomerace's Avatar
Re: Miniflash Saga Continues - Tail Heavy
-Josh-
Setup:
Solite covering
Built with Thin CA
8 Cell 720 Nimh
GWS 300c-D Gearing
8 Channel Reciever
Hs 55 Servos.
The 720's with that setup just won't provide enough amps to get it flying with the weight! You need the 8-800 pack! As to the nose weight... I have the 8 cell Kan pack in mine with the mini AC setup and had to add nose weight to get it to balance where it should!
boomer
Apr 19, 2003, 06:11 PM
TeamZiering
enigmabomb's Avatar
Well, that was the first flight, I then put in some nice 700 Nicads. They would have flown it well... sans the weight problem.
-Josh-
Apr 19, 2003, 06:12 PM
TeamZiering
enigmabomb's Avatar
...What do I use to add weight. I need something more elegant than batteries taped on the cowl.
-Josh-
Apr 19, 2003, 06:17 PM
boomerace's Avatar
-Josh-
It's a tight fit but managed to get a couple of Model RR weight pieces inside the front of the nose! In the past I have in like cases drilled the balsa nose and inserted straight pieces of heavy coreless solder sticks epoxied or CAed in the holes and then recovered with covering material!
boomer
