Sep 14, 2009, 09:30 PM
Fresno CA, good old USA
Horton HO 229
I am thinking about building a 229 for my next project for me. I have a few Customer projects that I have to get out of the way first so it will be a month or so before I start. I figure I will use that time to ask questions and pick brains. So, has anyone built one? Mine will be 84 inches in span and use two ducted fans and retracts. Help me out guys, I need your expertise! I found a painting of a proposed night fighter version that I would like to copy.
Marion
Sep 14, 2009, 09:35 PM
Neophyte hacker
portablevcb's Avatar
Try writing to the Horton project at Northrup Grumman. They're building a full size for testing.
Sep 14, 2009, 10:05 PM
CaptAhab's Avatar
http://www.wingsontheweb.com/
Sep 14, 2009, 10:40 PM
Übung macht den Meister..
Deuce's Avatar
Oooh! Subscribed!
I'd like to offer some brains to pick, but I seem to be coming up short lately...
James
Sep 15, 2009, 05:38 AM
I builded two horten last year using, using my club's cnc. The first one was a simple glider to test the idea and the second is a propeller powered plane.
Both where 63 inches wing span and the second one have retract wheels and flaps.
The glider was flying well without rudder, but when I try to add engine on it, a small rudder became necessary.
It's a nice plane, very easy to fly.
Bye
Sep 15, 2009, 07:27 AM
Two left thumbs
Very nice, Eric. Will you eventually build a ducted fan version?
Your family name is very similar to that of the famous French designer of tailless aircraft, so perhaps building such models may be in your blood!
http://www.aviafrance.com/8263.htm
Geoff
Sep 15, 2009, 08:33 AM
Neophyte hacker
Ok, for the aero wizards, how can full size flying wings work without fins yet most models seem to need them?
Sep 15, 2009, 08:40 AM
vonJaerschky's Avatar
There is one under construction here: https://www.rcgroups.com/forums/showthread.php?t=791900
Sep 15, 2009, 09:08 AM
Pro Hoarder
turbonut's Avatar
Most model builders dont use the correct airfoil sections and wing layout..Some do..see the above link to wings on the web..
Latest blog entry: In flight
Sep 15, 2009, 12:30 PM
also at least four Ho 229 projects in the discussion/forum section of RCscalebuilder.com. search on H0 229. you probably need to register to search some folders.
one of the guys posting was involved in designing and building a full scale mockup of the cockpit for the NG documentary.
there's lots of good tips on how to build one that will successfully fly. There's also a number of plans available out there of differing quality and closeness to scale appearance.
Sep 15, 2009, 12:48 PM
peterangus's Avatar
This tiny card chuck glider, with minimal side area, flys remarkably well.
Perhaps the secret is in the planform.
Sep 15, 2009, 02:20 PM
Pro Hoarder
turbonut's Avatar
Gary Heathcoat
Yes that was Gary(not sure of his last name spelling)..I have his large 229 kit(still in the box)
Sep 15, 2009, 04:23 PM
Geoff
The first one, after successful gliding was tested with 2 55-gws ducted fan. All the test with the engines was unsuccessful. First the plane seem to be under powered with this small fan (each give 280g thrust with brushless engine), also the fan blow seem to give aerodynamic instability.
After several try, I put a propeller in front of the wing and a small rudder and it flew perfectly. I also made a test fly with the propeller engin without the rudder and the plane was crash.
It seems to me that a powered plane need more stability than a glider.
My horten is build with a Horten 13% profile in the center section and a symmetrical horten 10% profile in the wing extremity. A negative 5° twist is apply to the extremity of the wing.
Two pictures : the glider without rudder (fly well) and the same with the two fans (crash well !).
Regards
Sep 15, 2009, 05:31 PM
Wow! Thanks for all the info. I have seen enough to know that the one I am wanting to build will fly. I met the guy who drew the plans at an IMAA contest a couple years ago and he had his there. He didnt fly it as the weather was terrible. I see that a kit is available for only 495.00 dollars. A little steep for me. I will scratch off of my plans. It would be a beatiful kit to build but that is like my annual model money in one poof.With the scale nose wheel it looks like a large angle of attack, will it take off ok? I have to fly my Waterman off with up or it will just head down the runway with no inclination to fly.
Marion
Sep 15, 2009, 07:28 PM
sml
sml
Marion
You can get the all wood plans here for only $49.95.
http://yhst-14835714857193.stores.ya...en-ho-229.html
Saul
Ho 229 Build northropn9m Flying Wings 154 Oct 22, 2009 05:42 PM
Wanted RBC Horton Ho XIIIB ShaverR6 Aircraft - Electric - Jets (FS/W) 2 Nov 27, 2006 09:25 PM
Discussion Power for an EDF HO 229? 4 Scale Electric Ducted Fan Jet Talk 9 Aug 08, 2006 07:55 PM
Ho 229 Tempest Electric Ducted Fan Jet Talk 0 Nov 05, 2004 04:39 PM
Jack Cooper's ho 229 (sting wing) mothflyer Slope 4 Sep 01, 2003 11:26 AM
