Sep 14, 2009, 06:30 AM
MelihK's Avatar
New Product
SimpleOSD Ultralight & XL editions, Now Shipping!
Hi Everyone,
Important Notice: This first post will update when product specifications changed.
We started a new thread about simple and cheap OSD system on FPV community.
http://fpv-community.com/forum/showt...tid=148&page=1
Concept is "flying like a bird without OSD scraps on the screen"
This is why SimpleOSD using smallest fonts and only 1 line OSD information on top.
First product of simpleOSD concept coming in this week!
UltraLight: http://www.flytron.com/29-simpleosd-...t-edition.html
XL: http://www.flytron.com/41-simpleosd-xl-edition.html
Original SimpleOSD UL(ultra Light) board is only 3.16gr weight.
UltraLight edition usefull for Non GPS usage.
I'm suggesting XL version if you want using it with GPS, because XL version have 4 times bigger firmware capacity for complex calculations.
It is monitoring 2 battery voltage and capacity and current(with optional current sensor)
SimpleOSD system is firmware upgradible over internet and i will design different firmwares for different usages like dogfighting osd with bullet and hit counter.
I hope you like it
Some features:
* Plug and Play interface for easy usage
* 32kb giant size codespace for different screen designs(on XL version)
* 8kb codespace for simple and usefull screen(on UltraLight version)
* Optional 10hz GPS module with -163dB high sensitive active antenna
* Optional Plug and Play 2.4ghz and 5.8ghz TX modules
* Second battery monitor
* RSSI input pin for signal level monitoring
* Optional analog pin for different sensors
* 27x35mm stamp size
* IR port for Infrared Dogfight and menu control with TV remote (XL version only)
* EXT port for remote controls, digital outputs or IR gun for dogfight
* Firmware update system over internet
Photo showing Pro edition with GPS and Current sensors.
The size Comparison of OSD,GPS,Tx module and garage remote battery.
Sep 14, 2009, 06:49 AM
trappy's Avatar
If the sensors are not connected, does it hide the text for it? Is it possible to get a "special" firmware mod? I'd like to have one where voltage shows up every 5mins for 5 seconds.
Sep 14, 2009, 07:27 AM
MelihK's Avatar
Hi Trappy,
Yes, it checking sensors on startup and showing only connected ones.
Me and you was talking about this, It will have time delay and on alarm options.
Sep 14, 2009, 07:30 AM
trappy's Avatar
Great. Really nice. I'm getting one for sure. How's the power consumption and can it be just put between the 5V/12V camera and tx (powers off the camera circuit)?
Sep 14, 2009, 07:55 AM
MelihK's Avatar
System need only 10mA for OSD,
add extra 50mA If you want using with GPS.
Sep 14, 2009, 08:53 AM
Will this OSD have a "Home" location to be able to get back to your starting point?
Mark
well after taking a closer look I see the home Icon..
Please let me know when it is available :-)
Sep 14, 2009, 09:14 AM
Capy-Norway's Avatar
what's the price for osd, gps and current sensor?
Sep 14, 2009, 09:21 AM
MelihK's Avatar
Hi Mark,
Yes you can use with 10Hz GPS module for home/altitude/distance/speed informations. But is increasing cost and weight, not usefull for UltraLight edition.
I suggest you SimpleOSD XL edition, I need 1 month for finishing first firmware.
Price will around $110 with GPS module. XL edition have powerfull microprocessor and extra inputs for making very funny things.
Sep 14, 2009, 09:35 AM
MelihK's Avatar
SimpleOSD UltraLight edition will $42
It is cheap and usefull for lowcost or dangerous FPV actions.
You can follow prices and new parts from here
http://www.flytron.com/2-fpv-equipments
Sep 14, 2009, 03:53 PM
MelihK's Avatar
News from SimpleOSD project
- GPS modules received
- Plug and play sensor system is ready!
- Source code optimised,
- Current Sensor codes working,
This is last photo of my desk
And this is last screenshot, it showing voltage,current,capacity usage and altitude(from gps)
I will sleep (midnight here) now , see you tomorrow
Sep 14, 2009, 08:14 PM
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
This is cool,I'm looking for something small to fit in my Fox.
This looks like it will work perfect, will this work for PAL/NTSC??
Sep 15, 2009, 07:16 PM
I dont have much room in the payload bay of my Micro Grey Ghost either, this would work. I dont like a cluttered video feed, SimpleOSD looks really good. Need any beta testers??
Sep 15, 2009, 07:20 PM
That has got to be a winner!
Sep 15, 2009, 07:41 PM
trappy's Avatar
Melik, I see on your testbench you are using vertical pins. In final product you should either deliver 90deg bends or unpopulated hols with both choices. Some applications (mine for example) require the OSD to be flat as possible.
Sep 15, 2009, 11:20 PM
MelihK's Avatar
Originally Posted by trappy
Mark, I see on your testbench you are using vertical pins. In final product you should either deliver 90deg bends or unpopulated hols with both choices. Some applications (mine for example) require the OSD to be flat as possible.
Yes, you right.
I will sell it flat and included different pins. you can solder the pins.
My personal choose is using without pins.
If you want watch only the voltage, you need only 3 wire. (power, ground and video signal)
Yes, and it will detect the video system automatically when startup
F-84 Thunderjet - Coming Soon 356Jim Electric Ducted Fan Jet Talk 4 Oct 25, 2007 07:42 AM
Coming Soon from Ryan Aircraft Jim Ryan Scale Kit/Scratch Built 33 May 07, 2002 07:42 AM
eflightproducts.com- COMING SOON Paul Penney Vendor Talk 13 Jan 09, 2002 03:33 PM
Partenavia video coming soon........ E-Lee Foamies (Kits) 6 Dec 04, 2001 12:55 PM
U2 Slope Scale- Coming soon rtrigo Electric Sailplanes 2 Jun 28, 2001 08:29 AM
