Hmmm, yes we need Franky and Gary to duplicate some more planes in the new model. I find the extra two to be flawed, but I don't now if I can explain it because I am not good with acrobatic nomenclature. Anyway, just getting up in the air and then trying to do a flat spin type manuever with only full left rudder and then rolling aileron into a right roll several times caused the plane to fall out of the air unrecoverable like it had crashed. This happened serveral times. today. The cessna of course can be edited but wow needs lots of elevator trim. I don't know that I don't find the prior version realistic enough for me. The cessna does fly with more wind more realistically and I do think parts of the extra fly better... Not meaning to complain, just being honest. And I don't know how to fix or change the model parameters well enough either. Davy, still a home run in my books!!! Maybe just not quite a grand slam yet.
Reason: Forgot my last sentence as the grand slam is different landscapes. :)
I found both Cessna's to be improved - more power and control, but version 2 was better I thought. The Extra's were both difficult to take off, so I calibrated my ESky controller with Windows7. After calibrating, I noticed that the X rotation (rudder) went from one extreme to the other, with no middle. I then went to default setting and the x rotation appeared normal then. My takeoff problems with the Extras were solved by backing off a little from full up elevator. Once in the air, both flew well, again version 2 was better. I also flew the t-28 Trojan, Hawksky (thanks Gary!), Chara Bipe and Tandem Bipe (thanks Frankie!). All seemed to have more power and control. The wind flag is very nice and I love the chase view! |
GF,
Just gave both versions old/new a quick run through. I really like the new physics. I will have to read up on how to convert them. I still am not able to make a good snap roll using conventional stick movement. It might just be the settings aren't quite right yet. I will play with it some more. I found a bug or two when I assumed that I needed 3D to use the new flight physics. It maxes out some of the flight parameters and things go awry after that. So, instead of just letting loose, let me read the docs to see what's new. -- ggunners |
Thanks for all the comments.
You were right about needing the "advanced (3D)" model. That selects the new flight model. After that you need to reset the Dimensions, namely wingspan and "right wing center". Simply move the latter to the center of lift of the right wing. The last thing that needs changing then is the agility parameters, to be specific everything related to the ailerons and dihedral. That should be it. I'll update the manual before the final release. Quote:
Davy |
Hi Davy
New to R/C Desk Pilot and have just downloaded/installed 0.1.2. I can't seem, to add planes? Looked in your blog and saw that the exe should create a folder: "My Documents\RC Desk Pilot\Aircraft" which it did'nt. Is this functionality only available in the beta: 0.1.3? Any downside to going to 0.1.3? And to install can I install over the top of 1.1.2? Sorry for all the questions, great sim!! PS: I did search the thread, sorry if this has been asked multiple times! |
Have fun! Davy |
Davy ive only got a little time on the new sim been sick and busy but heres a few things ive noticed that differ from flying my real planes .
With full rudder on the cessna i dont have to add any aileron control to compensate for inside wing dropping . No selfrighting tendincy to the cessna Cessna and others Can fly straight all day in the windiest conditions . doesnt effect wings /fuselage independent ie doesnt blow 1 wing up or back more then the other when at an angle . Your doing a great job and im hoping to get a little more time at it this week , just hard to give up flying the real thing when its been so nice out lately Chris |
So, Davy and others, is it just me with the extra 2 having a few difficulties in flight?. I guess I am going to fly the extra with the same manuever and see how it does. That should tell me if its me or perhaps a bug... schmaybe?
Messed with it quite a bit. Extra 2 is worlds apart actually. What I am noticing is when cutting throttle off completely and then kicking it back on. My guess is that I can tweak this somewhat in the delay setting. Momentum seems to drop too quickly when dropping off power quickly and completely. As long as I keep a few clicks above the bottom it flies really well.
Here is my tweaked par file for the extra 2. At least I like it better this way...
Played more after trimming the extra to my liking. Many manuevers seemed to improve and then I went to lots of turbulence and wind. I fly in wind most of the time in real life and like surfing and 'flying' backwards. The sim does a good job at simulating that now too. It also allows one to practice landings in variable hard gusts which can be a plane thrashing experience in real life and something that needs some practice.
Neither am I really, but I can do a few basic manuevers.Copy all you want, doesn't mean yours aren't right, I just like my changes for me.
Thread Tools | |
Similar Threads | |||||
Discussion | Atlanta area micro r/c heli pilot needed ASAP | Greg McNair | Aerial Photography | 1 | Nov 13, 2006 06:20 AM |
For Sale | (71)r/c digest mags up for bid | bigtfortulsa | Aircraft - Sailplanes (FS/W) | 0 | Jan 11, 2006 09:29 AM |
For Sale | Old r/c Digest magazines up for bid | bigtfortulsa | Non R/C Items (FS/W) | 0 | Jan 11, 2006 09:24 AM |
R/C Airship Pilot Needed - Orlando, FL | Stevens AeroModel | Parkflyers | 4 | Mar 18, 2002 10:24 PM |
