Aug 26, 2009, 02:43 AM
Cool
The unique water-cooling brushless outrunner motor with water circling in the center
AEO ADS -300 water cooling motor advance:
Breaking through the traditional cooling way. The cool water contacts with heat source of the motor directly, not to increace motor dimension at the same time.
Ultra-high heat sink efficiency, making it life longer by the water cooling circle in the center of the motor.
Compared with traditional outside cooling way of outrunner water-cooling motor, the breakthrough of AEO water-cooling motor: Cool the stator inside motor directly:
Traditionally, there is a special cooling area in the front of motor.
AEO cooling way called "Center pillar cooling". The cool water circles in the center pillar to get away the heat.
Aug 26, 2009, 02:49 AM
Grumpa Tom
Kmot's Avatar
Tell me more.
Aug 26, 2009, 03:49 AM
Tell me more too.
Aug 26, 2009, 04:23 AM
Is life for real?
pkboo's Avatar
You got my attention! Boo
Aug 26, 2009, 06:51 AM
London RC Project
BrotherBloat's Avatar
nice!!
Aug 26, 2009, 06:55 AM
yep! any specs or datasheet?
Aug 26, 2009, 07:11 AM
Checking CG is for NERDS!
Smokescreen38's Avatar
Ooohh... neat! This has my attention.
Does it work as it's own pump? If so, how much drag does this put on the motor?
Where is the radiator/heat exchanger?
How much water do you have to carry?
EDIT:
Ha-- just saw this was in the racing boat section that answers all except for my first question!
I'm a plane guy... I suspect that this won't be all that valuable for me...but it's still really coool.
Aug 26, 2009, 07:16 AM
Boaters are nice people.
Nice!
In fact this way of cooling the stator has been used in large outrunner for some time, it was a matter of time before someone took the trouble of making it small and durable enough for smaller outrunners.
This opens up a lot of opportunities for using outrunners in boats.
Regards, Jan.
Aug 26, 2009, 08:36 AM
TheyreComingToTakeMeAway!
derk's Avatar
i say dont get too excited, AEO made a 30mm fan unit that was absolute junk untill people started modifying them, after about a year, they finally started to fix their production units.
Aug 26, 2009, 09:22 AM
Originally Posted by BrotherBloat
nice!!
Aug 26, 2009, 09:23 AM
Specifications
Weight: 43.4g
Dimension: 23mm*46mm
Length of shaft: 14mm
KV: 3000 ( according to customers special request )
Thanks & Regards
Tang
Aug 26, 2009, 09:29 AM
Originally Posted by pompebled
Nice!
Regards, Jan.
AEO ADS300 can meet this need.
Weight: 43.4g
Thanks & Regards
Tang
Aug 26, 2009, 09:59 AM
The motor has been integrated with EDF to enhance the balance.
AEO new fan will be released this week. This new fan uses more stronger material to improve efficiency.
We are working to improve performance all the time.
Thanks and Regards
Tang
Aug 26, 2009, 10:01 AM
If new product released, we will send some free samples to you. Public can help us to test if it available or not.
Thanks & Regards
Tang
Aug 26, 2009, 11:13 AM
Hi Tang,
I'd be willing to test one of your free samples in one of my small speedboat hulls to see how it holds up...
A 3600 - 4000KV would be nice
Regards, Jan.
Sold BL-2212/13 Brushless Outrunner Motor with Mounting Bracket and Prop Saver and 20A ESC CitizenKane Aircraft - Electric - Power Systems (FS/W) 2 Aug 12, 2009 10:35 AM
Help! Tonic-X Z10A 3700KV Brushless Outrunner Motor with Fan gliew Power Systems 2 Mar 19, 2009 06:53 AM
Article Experimenting with Eskay's 400XT Universal Brushless Outrunner Motor Reviewette kingsflyer Power Systems 408 Jan 26, 2009 11:32 AM
Sold E-flite 450 Brushless Outrunner Motor (890Kv) with E-flite 22A Brushless ESC JohnM Aircraft - Electric - Power Systems (FS/W) 3 Oct 19, 2007 11:11 AM
Help! Big Problem with my TowPro 2406-32 Brushless Outrunner Motor Pipercub18 Power Systems 12 Oct 20, 2006 03:40 PM
