Aug 06, 2009, 09:33 PM
Registered Abuser
rolexcomex's Avatar
Help me solve this problem.. ESC?, BEC? or RX?
Last week, flying a funjet on 4s, using a CC 80 amp esc and CCBEC, and AR6200 rx. Flying close by, all the sudden the motor shuts down but I still have power to dead stick it.
The ESC is beeping four times every few seconds. I could not find much information on the CC website or the net...
A few days ago. Same plane, batt and setup.. doing a high speed turn (125mph) far from me (about 500-700 feet) all the sudden, the motor still running but there is no controls and the plain continues in a high speed turn and into the ground no matter what I tried to do to correct it.
I initially, I blamed a lockout on the AR6200
But after trying to build a new funjet.. Had everything connected, I then pulled the CC BEC wire to the RX.. no power to the RX, no controls. I then replugged it while still connected, bingo.. full controls, and four beeps from the CC ESC.. Reproduction of at least the original problem.
So the question.. What caused this?
1. Low voltage? then no power to rx? Why? Avoid the AR6200 and use AR7000 instead????
2. CC BEC did not work properly?
3. CC ESC? I dont think so.
4. AR6200 low tolerance to changes in voltage?
I am not trying to fault anyone, just trying not to make the same mistake again..
Any input would be greatly appreciated...
Help! please help me ID this ESC. nakman8 Power Systems 3 May 05, 2009 10:00 PM
Discussion Please help me identify this ESC to program it wizvaahz Power Systems 8 Aug 08, 2008 11:06 AM
Discussion Can someone help me identify this ESC? dwelch Mini Helis 4 May 27, 2007 10:11 AM
Please help me identify this ESC mjfdassen Power Systems 5 Sep 27, 2005 07:32 PM
Help Me Solve This Power Mystery.... JIMJAM Power Systems 5 Nov 02, 2003 06:44 PM
