Apr 13, 2010, 11:45 AM
noppita's Avatar
i noticed that you put the information on how to make i2c pwm converter on your site, which if i decide to try making one, i then have to make pcb and buy electronic component to make a complete i2c pwm converter. however, i like to know if you can sell the complete i2c pwm converter to me and how much for 3 units?
Apr 13, 2010, 09:02 PM
noppita's Avatar
Originally Posted by Willa1980
I could already test the HK SS 18-20A with my converters in flight. TowerPro will most likely work too, but I do not have experience with it in flight.
so, you are using Tower pro n18A with your current version, which you modified the ESC without using i2c pwm converter, and you never tried this unmodified Tower pro n18A with the i2c. I can not order HK SS18-20A because of back order for over 20 pieces, therefore if you think that this Tower pro n18A should work as well, then i just going to use it and try it.
Apr 14, 2010, 01:23 AM
Shrediquetter
Willa1980's Avatar
Correct. But I tested an unmodified TowerPro n18A on the ground with the converters and it seemed to work with 417Hz.
Apr 14, 2010, 01:53 AM
Hi William, 2 questions please?
- I bought these ESC's, I'm sure they will work with the 3 i2c boards you sent? Hobbyking SS Series 25-30A ESC
- I noticed last night when finishing the yaw servo part that there is a small amount (1mm) of play on the servo, will that make a difference?
By the way, I was informed this morning the parts you sent is at my post office, yippeeee!
Cheers
Dion
Apr 14, 2010, 02:12 AM
Shrediquetter
Willa1980's Avatar
Hi Dion,
the ESCs should work. Play in the servo is not good, especially because 1mm is a huge play in my opinion. Doesn't the play decrease if you switch on the servo?
Apr 14, 2010, 02:27 AM
Oh no. The play is less when powered on but still there, seems like play in the actual gears of the servo? Do you think I should try it or rather find another one?
Apr 14, 2010, 02:22 PM
cvandenb's Avatar
Play is never good. "play" will make the unit twitchy, unstable and unpredictable.
Servo's should never have any play, play indicates wear and the possibility of failure.
Apr 15, 2010, 12:40 AM
Managed to get it basically rock solid now. The play in the servo basically goes away when powered on. It seems like most of the play was in the 2 ball links I had so I replaced that with a straight Z bend push rod, lots better
Now my next question William:
I checked the Tri-Guide, IMU block and Rec-Enc last night and everything works 100%, Thanks!
- Will the first flight be done with all standard settings and go from there or do I load the Settings_William file?
- The yaw has got a lot of travel, I'm talking about 45 degrees in each direction and is very sensitive, is this normal or how do I decrease the throw?
Thanks!
Dion
Apr 15, 2010, 06:23 AM
FPV Junkie
tazdevil's Avatar
hI Willa
my tricopter board working with dragon link receiver, I can see servo travel and gyro work on trigui
but , since I burn the original arduino I have, cause of ground bad contact on new white board, I reroute all te bord and add wire to make good contact betwhen dc/ dc regulator. to ground
I think you will make new board with 16/10 e epoxy material it could be stronger
Anyway,
I buy a new arduino , flash it and check it, all is working on the trigui eccept I have to put new parameter on the board.
When I select the "load file and load to the uc" it's impossible to open the window with the chose file option.
every time I have an error on the soft :
Consultez la fin de ce message pour plus de détails sur l'appel du débogage
juste-à-temps (JIT) à la place de cette boîte de dialogue.
************** Texte de l'exception **************
System.MissingMethodException: Méthode introuvable : 'System.String System.Windows.Forms.OpenFileDialog.get_SafeFileNa me()'.
à TriGUI_v1.MainForm.ReadsettingsClick(Object sender, EventArgs e)
à System.Windows.Forms.Control.OnClick(EventArgs e)
à System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
à System.Windows.Forms.Control.WndProc(Message& m)
à System.Windows.Forms.ButtonBase.WndProc(Message& m)
à System.Windows.Forms.Button.WndProc(Message& m)
à System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assemblys chargés **************
mscorlib
Version de l'assembly : 2.0.0.0
Version Win32 : 2.0.50727.42 (RTM.050727-4200)
CodeBase : file:///C:/SYS/WINDOWS/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
TriGUI_v1
Version de l'assembly : 1.0.3708.32535
Version Win32 : 1.0.3708.32535
CodeBase : file:///C:/Documents%20and%20Settings/e270412/Desktop/Desktop/tricopter-atmega/all_02_2010/TriGUI_last/TriGUI_v1.exe
Microsoft.VisualBasic
Version de l'assembly : 8.0.0.0
Version Win32 : 8.0.50727.42 (RTM.050727-4200)
CodeBase : file:///C:/SYS/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase : file:///C:/SYS/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase : file:///C:/SYS/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase : file:///C:/SYS/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase : file:///C:/SYS/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
mscorlib.resources
System.Windows.Forms.resources
CodeBase : file:///C:/SYS/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_fr_b77a5c561934e089/System.Windows.Forms.resources.dll
************** Débogage JIT **************
Pour activer le débogage juste-à-temps (JIT), le fichier de configuration pour cette
application ou cet ordinateur (machine.config) doit avoir la valeur
jitDebugging définie dans la section system.windows.forms.
L'application doit également être compilée avec le débogage
activé.
Par exemple :
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Lorsque le débogage juste-à-temps est activé, les exceptions non gérées
seront envoyées au débogueur JIT inscrit sur l'ordinateur
plutôt que d'être gérées par cette boîte de dialogue.
any idea ?
Apr 15, 2010, 08:01 AM
FPV Junkie
tazdevil's Avatar
Arf , i Found I was aving the old version of .net and can't upgrade it at work ..
thank anyway
No need to convert my towerpro 50 amp controler
Originally Posted by tazdevil
hI Willa
Anyway,
mscorlib
TriGUI_v1
System
System.Drawing
mscorlib.resources
activé.
Par exemple :
<configuration>
</configuration>
any idea ?
Apr 17, 2010, 06:56 PM
Shrediquetter
Willa1980's Avatar
The frame was milled by rcgroups user 17b (thanks :-D !).
Here are the latest vids of my micro-tricopter:
second flight (indoor):
(1 min 26 sec)
second outdoor flight (flips and hands-free hover + onboard HD vid):
(3 min 40 sec)
The videos are pretty boring, but they show how the DLXm flies...
In order to have stable flights outdoors with aerobatics etc. I had to change some things in the tricopter firmware. Now my micro-tricopter flies even better than the large tricopter with the old firmware. I am curious how the large tricopter will behave with the new firmware. But testing will take a while since I only afforded one single IMU cube for both my tricopters. As soon as I did some tests, I will release a new firmware and a modified GUI. The new GUI will only work with the new firmware and vice-versa.
Apr 18, 2010, 12:06 AM
Nice william!
DLXm flies very fantastic with your skill.
I hope I'll fly DLXm soon.
Apr 18, 2010, 04:41 AM
WOW, very nice!!!!
Apr 20, 2010, 04:30 AM
Shrediquetter
Willa1980's Avatar
Hi,
a better video is finished showing how nicely the little thing flies :-D
(3 min 37 sec)
Apr 20, 2010, 08:30 PM
Gwarden-98's Avatar
William, you are amazing!!!- If I had a gillion dollars I'd hire you to be my evil genius and we would take over the world together! Keep up the incredible multicopter work, I'm certain some day we will all be able to benefit from your work directly (at least those of us building and flying multicopters).
Discussion GPS position hold for helis? zaguruinzasky Aerial Photography 6 Dec 31, 2008 12:19 PM
