Jul 30, 2009, 06:07 AM
funny stuff Max, the Fox is a tough little bugger
looks like you're having a ball with it
Darren
Jul 30, 2009, 06:15 AM
Questionable judgement
bracky72's Avatar
This looks wonderful. Good work!
Jul 30, 2009, 07:23 AM
Time's fun when ya havin flies
cncoz's Avatar
Well done Max !
I can appreciate how hard that is, I've broke planes trying to do similar things.
I've gotta make me a FPV Fox, I've already got all the bits to make one (except a suitable prop).
Looks like you guys have a stack of fun, Must get up to your field one day for a look-see.
BTW Sorry to hear your mini-DV doesn't work, mine arrived and it works good !
Hope to roll some tape this weekend.
Congrats again on a great thread !
Graeme
Jul 30, 2009, 09:30 AM
Flying FPV from the lab.
aaron_gx's Avatar
Originally Posted by chancesAU
Yea what do you expect from such a cheap camera hehe
Ive been told by many that its missing the IR filter...
I have a CMOS cam that has a similar washed out color look to it. Would adding an IR filter help with the color? The cam has great resolution and light handling, but lacks good color.
What does an IR filter consist of, and where does it go? Behind the lens, or on the sensor?
Jul 30, 2009, 11:33 AM
Mr.Pibb's Avatar
Sometimes the filters are attached to the lens assembly, and sometimes they are right in front of the CMOS sensor. if you happened to switch out lenses, odds are there was an IR filter on the lens that isn't on the new lens.
Aug 01, 2009, 01:30 PM
ChancesAu,
I have ordered 2 cameras and lenses from the ebay seller.
It will be interesting to try these.
(and even more interesting to find something to fly under )
Aug 01, 2009, 03:59 PM
Live FPV or Die
VRflyer's Avatar
cmos camera need special lens, effectively they have coating on it. I use Killerccd on my Fox and I'm luchy to know Greg at Fatshark, I was able to get a wide angle lens for cmos cam. i got 20 lens here for ccd camera, anyone i try, I got weird color it's normal.
Aug 01, 2009, 04:23 PM
Live FPV or Die
VRflyer's Avatar
FPV fox with osd
I also build a Fox few weeks ago but had few chances to try it due to the weather.
I use mainly Fatshark equipement for this project, the Killerccd camera with a wide angle lens give a beautifull picture, but it need sun unless the picture appear darker compare to RCV922 camera. The Immersion 10mW tx, 2,4ghz is very light and it can operate directly from the 360mAh 2S lipo use for the motor. The camera is mount on a panning servo modified for 180deg, but the resistor I had use give me only 120deg in real. The picture is receive in my Fatshark goggle and I use a headtracker to pan the camera. The camera have two microphone, I received the sound in stereo But I don't use the earphone, too noisy...
I use a 10gr motor and a 10A ESC mount in front of the plane. two servo are use for ailerons and one mount in the tail for the elevator. All servo are 3.7gr. The receiver is a Berg7p, the case was remove and the servo wire are weld directly on the receiver, no connector.
I will upgrade soon the osd onboard my other plane (Cap232) to a more powerfull one, and I will take the Alti-osd presently in the Cap to install it in the Fox. This osd without the connector pins will weight around 5gr. It will add the altitude, voltage and temperature in the video picture.
I don't have any decent video, I will go tonight flying in a park with it, perhaps I will get the sun this time to make a good video.
Fatshark Goggle with 10Mw TX): http://www.nghobbies.com/cart/index....roducts_id=130
Camera: http://www.nghobbies.com/cart/index....roducts_id=122 (NTSC version)
Headtracker: http://www.nghobbies.com/cart/index....roducts_id=157
motor: http://www.hobbycity.com/hobbycity/s...idProduct=5358
esc: http://www.hobbycity.com/hobbycity/s...idProduct=4204
prop:http://www.hobbycity.com/hobbycity/s...idProduct=7937
Servos: http://www.hobbycity.com/hobbycity/s...idProduct=3715
Lipo: http://www.hobbycity.com/hobbycity/s...idProduct=7301
Alti-OSD: http://www.kapelec.com/altiose1.htm
Aug 01, 2009, 08:36 PM
chancesAU's Avatar
Wow thats sweeeeet
Love the canopy setup... and the OSD is unreal, look forward to some neat videos!.
Max
Aug 01, 2009, 09:50 PM
Mr.Pibb's Avatar
Denis,
That looks great! I can't believe you have the steady hands and patience to modify that little servo.
I've been considering building these with a single servo for ailerons. Did you try that initially? I see there's an orange plug on the top.
I may also try rudder only control. I've seen some people do that, but I really don't know how well that would work on this plane. I want to keep the build as simple as possible. I probalby won't have pan on the camera intially, I may eventually try that. I just don't think I have the patience to do what you did to the servo, and my pan module is a tad big for this plane.
I like that notch in the bottom for equipment. I may have to try that out too!
Aug 01, 2009, 10:51 PM
Live FPV or Die
VRflyer's Avatar
Yes I installed the two servos initially in the wings. My idea about the orange square was to add a foam piece on top to protect the camera and tx for hard landing, but it's so light it become not neccessary so I removed it.
I would install one servo on top for both ailerons for my next Fox. Rudder will not be enough effective, you will not be able to fly low between obstacles, and this is the goal, this plane is near indestructible, but it's easy to lost it in a tree
Also I did not say it before but i change the angle of stabilisator by cutting the foam. Now it in line with the fuse. Initially it have an angle that give me impression it will go directly in the ground at first launch. I'm the only to have done that... so I think it was not neccessary. But the plane fly very well.
Here is my first Fox video. Light wind and the sun was low at the horizon. My camera need sunlight and high in the sky to perform at his best for my kind of flying low, very low
FPV micro plane Fox (6 min 48 sec)
Aug 01, 2009, 11:38 PM
Mr.Pibb's Avatar
I've seen that park before!
I'm excited for my parts to show up. That looks like a blast...
Aug 02, 2009, 12:31 AM
skunkworks2006's Avatar
I used just one 5g servo for ailerons and it worked out really well for me. I mounted it underneath the wing. I haven't put FPV equipment in mine yet, but as soon as I have a bit more time....
Just TOO much FUN. Perfect little "take anywhere" FPV ship. I imagine that with the Fatshark set up there is even less to lug around.
You can see my Fox at the bottom of this page:
https://www.rcgroups.com/forums/show...ght=skunkworks
I have another airframe ready for conversion. I think next time, I will use a smaller CF rod and shorter in length for the main wing.
Aug 02, 2009, 02:21 AM
vr
very cool video
nice set up
thanks for the links
Aug 15, 2009, 07:16 PM
Live FPV or Die
VRflyer's Avatar
I installed the osd in my Fox, it still fly well. Weight: 145g
FOX micro FPV plane (6 min 32 sec)
Discussion Multiplex Fox psychopic Foamies (Kits) 2870 Dec 04, 2018 08:15 PM
Discussion Multiplex FOX aleXtino Hitec/Multiplex USA 14 Sep 19, 2008 04:54 PM
Discussion Multiplex Minimag FPV mr-02 FPV Talk 20 Feb 02, 2008 07:25 AM
Build Log Multiplex EasyGlider Electric Build becsta Electric Sailplanes 13 Jun 06, 2006 10:36 PM
Discussion Multiplex EasyGlider - Started build - how's it look ? JustGoFly Foamies (Kits) 0 Dec 28, 2005 07:35 PM
