Jul 24, 2009, 07:55 PM
Help!
Durable fast large payload plane?
I need a plane that is strong enough to take a few hard hits, big enough to carry a 3-5lb payload, relatively stable and fast enough to be fun(>70mph). any ideas?
Jul 25, 2009, 01:40 AM
Here's my newest bud
Aero Ace Ace's Avatar
Sounds like a custom job for you. I'd suggest a large flying wing, or a large foamie jet, but it won't be fun until you remove the payload.
Jul 25, 2009, 08:38 AM
Airboatflyingshp's Avatar
Custom yep.............possibly spad ....payload and toughness easy with a Mud Duck huge fun but not the speed..........16mph............ unless you build a new fuselage..................?
Scale big pod and booms designs..............probably twins Gotha - Powered Glider inspired .........or Cessna Skymaster. FW UHU.. P38 or P61 Blackwidow
Blue foam construction obeechi or brown papercovered covered - Flying Boxcar, HS Argosy inspired ......... nice but its a 4 engine, still thats more power.
More conventional GAF nomad, BN Islander large scale.
Giant Pusher jets HS sea vixen or Vulcan inspired large swept wing clean for speed but big wing area for carrying payloads.
Jul 25, 2009, 09:26 AM
Site Aspie
Lynxman's Avatar
Do you plan to smuggle something?
Jul 25, 2009, 11:52 AM
a flying wing would be the eaziest way to go
Jul 25, 2009, 12:14 PM
D.G.B.
KOMET 44's Avatar
Go here , www.btemodels.com Bruce can help you .
KOMET44
Latest blog entry: phasor 15-4 old skool
Jul 25, 2009, 12:19 PM
no im not smuggling anything...yet.... The payload is an IR camera microcontroller, about 20 sensors, daytime camera and Tx/Rx
Jul 25, 2009, 12:22 PM
I like the wing idea, but how stable are they? perhapse EPP foam plated with something: fiberglass, carbon....titanium?
Jul 25, 2009, 01:23 PM
carbon fiber strips perhaps?
Jul 25, 2009, 02:51 PM
doesnt carbon fiber need an autoclave to cure?
Jul 29, 2009, 11:31 AM
Search the AP and UAV threads youl find Carbon exoskeleton wings but they are not cheap..............a podded wing design might be easier you could take your inspiration from a vintage design called Gross Wing... https://www.rcgroups.com/forums/show...ge+flyingwings Cherpaa sounds good given the update treatment
Enlarge and update blue foam ribs or wing core on carbon tapering tube spars, use fishing rod/pole sections, with box LE and TE's
You could build a giant Mugi Evo..its been done.
Found this http://www.hobbycity.com/hobbycity/s...4&v=&sortlist= JIC
Aug 03, 2009, 12:07 AM
Is there any foreseeable design flaw in completely plating a 60-100" EPP wing in carbon?
Aug 03, 2009, 09:57 AM
Cost ................ and repairs........... you need to ask someone who can afford to play with that stuff.
Aug 30, 2009, 10:10 PM
Isaiah 40:31
rc capo's Avatar
how about a classic
Plenty of room in the fuse...the cby 3 had more headroom than a 747
Aug 30, 2009, 11:03 PM
You need to go ask the sailplane guys these questions.
Basically, you're asking for a big electric sailplane. The design and construction methods are all well known, but they're not cheap.
In short, no, no problem in covering a foam wing in fiberglass, basalt, or carbon, so long as you do it right. You will need a decent spar as well.
You might be able to find an off-the-shelf airframe that can do this job if you look at a specialist sailplane supplier. Heck, your payload is only a couple of kilos... you might be able to cram it into a Cularis.
Help! Durable fast large payload plane? swshouse High Performance 2 Jul 24, 2009 06:52 PM
Large 3D plane Bill Mixon Sport Planes 49 Oct 26, 2003 04:15 PM
How fast does that plane go ?????? Keithw Electric Plane Talk 6 Aug 06, 2001 04:41 PM
what's a small,fast,agile electric plane?..what is the model name of the Bare Bones? kiwip Sport Planes 27 Jul 20, 2001 05:32 PM
