Sep 02, 2013, 05:10 AM
please give me more hints. I don't understand.
Sep 02, 2013, 05:35 AM
guys this thread is only for EagleTree crew (Billpa) to alert, the users, in case of releasing new software update (Eagletree). (see the title of this thread "Latest Software Version info thread (DON'T POST TO THIS THREAD)")
Not change requests posted here, do it in a new thread.
@Heling: I think Xp783 would like to suggest changes to software.
Oct 22, 2013, 01:31 PM
Subscribe
Mar 31, 2014, 06:39 PM
artross26's Avatar
Aug 29, 2014, 01:39 AM
Denis's Avatar
billpa,
writting this link on your website http://www.eagletreesystems.com/Support/revision.htm
did it make sense
if there is no change history versions (change log)
Regard's
Denis
Aug 29, 2014, 06:52 PM
Jack
jackerbes's Avatar
Did you look at the revision histories on the download page?
http://www.eagletreesystems.com/inde...ormation_id=12
When you download their software it is a good ideas to rename the file as you save it to show the version you are saving. If you download version 10.52 change the default name from "setup.exe" to "setup_v10_52.exe" or something like that and you'll know what you have.
I have saved the versions as I moved up through them as just in case thing should I want to fall back to a previous version.
Jack (just a eLogger user, not a Eagle Tree employee)
Aug 30, 2014, 03:25 AM
Denis's Avatar
Yes i seen the revision history.
But there is no information about THE HISTORY
For example:
when a new software has buid "10.1"
Usualy there's informations about the changes between the 10.0 to 10.1
and the history between
10.1
10.0
9.0
Aug 30, 2014, 08:14 AM
Jack
jackerbes's Avatar
You are right of course, I had not actually looked at the revision history. It is really only a summary of the changes for the current version.
Good luck with your question...
Jack
Jan 19, 2019, 04:44 PM
Data Recorder BETA Software Version 10.72. In beta since August 12, 2016?
Last edited by quietfly; Jan 19, 2019 at 05:05 PM. Reason: Not supposed to post here. Sorry, I noticed after I already did.
Oct 09, 2019, 08:30 AM
Go4it's Avatar
So is thread dead? No post in almost a year.
You had a great question Beta software version 10.72 still in beta since Aug 12,2016-- So is it out of the beta testing and safe to use?????
Oct 09, 2019, 08:37 AM
According to Eagle Tree website it's still in beta ,,I've used it for awhile tho
Allen
Jul 18, 2020, 02:32 PM
"MAYONNAISE"
Acetronics's Avatar
Hi,
Does someone have success with the latests versions AND a Win 10 computer ???
Here, few years ago, I was just able to run the soft with an Ooooold WinXP SP3 and overall USB 1 !!!
With USB2 or 3 ( win XP or 10 ) , the initial window closes as soon as my Guardian is connected ...
E.T. service looks to be unable to have a decent ( read : working ) solution ...
Has someone found a turnaround since 2016 ???
Alain
Jul 18, 2020, 03:29 PM
eihoward's Avatar
I run on Windows 10 (ver 2004) USB 2, no problem.
Run the program, and connect the guardian when the program asks for it.
Jul 19, 2020, 02:11 AM
MLD
MLD
Usb speed
Hi all,
I don't have a solution, but you may try to find a working setup in bios configuration.
At power on of your computer, Press Fx . According the brand, it can be F2, or F3, or F9 or any Fx key. It may be displayed a few second before starting Windows
Then find the USB configuration menu
- Full Speed is the USB 1.0 speed
- Hi Speed is the USB 2.0 speed
You have also : Legacy usb support
You may also try also another USB port. If you have a desktop, use an USB port located behind which are directly on the motherboard. Not those at the front panel.
Hope this help
MLD
Jul 19, 2020, 06:08 AM
Petroleum1's Avatar
I run windows 10 and have no issues updating or programming guardians. Load program and plug in device it should acknowledge the plug in device. Also you could try deleting your eagle tree program and reloading and new copy.
Discussion How come you can't post in this thread? patrickegan AMA (Academy of Model Aeronautics) 2 Jul 30, 2007 07:10 PM
Discussion NVM don't post here Mr. Innocent Slope 22 Jan 19, 2006 06:18 PM
Don't you hate this? RhinoJL Parkflyers 33 May 23, 2003 05:00 AM
