A simple build Plank with KFm4 section.. with WOW! factor.. Called it the "Nifty" - Page 50 - RC Groups
Mar 10, 2017, 10:08 AM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
Dave , here’s my (your) 24” floppy 4mm EPP Nifty ... before bracing ... 2.2oz.
Found some bits of carbon fiber rods hanging around ... question is ( since you’re the designer eh ? ) should I add the CF rod to the LE of the wing or right at the juncture of the wing and KF strip ~ mid wing ( more spar-like ) ??? Can’t decide ...
I believe this is some very low density EPP ..
Mar 11, 2017, 04:39 AM
It seemed like a good idea!!!!
Hookit's Avatar
Shame you can't stiffen and keep that shape, I reckon it looks awesome with that curve.
Sort of like a Nifty Klingon Bird of Prey
Mar 11, 2017, 11:17 AM
gpw
gpw
gpw's Avatar
Found some bamboo slats from a place mat , so we glued them to the LE of the wing crossing in the middle , and one on the rear right onto the KF step ... (see pics ) Looks flyable as long as we don’t over power it ... weight gain was minimal ... so far ...
Mar 11, 2017, 12:59 PM
davereap's Avatar
the expensive way is too put a 5mm CF flat spar glued vertical along the step line.. and a 3mm CF flat along the leading edge..
But why no pallet strapping? and no laminating film? that would make the wing perfectly stiff..
you don't even need a full covering of laminating film, a few inches top and bottom, wrapped around the profiled leading edge and another few inches at the hinge line.. plus the elevons all covered.. will make it all stiff..
Mar 11, 2017, 01:05 PM
davereap's Avatar
The cut down 24" version has been flown today... starting with an 18% COG and moving it back to a 20% COG ...
20% is better, but still nose heavy as can be seen when it rolls..
the Emax 2204-2300 is not as powerful as I want.. so its now been swapped for a T2204-2280.. One of the T motors is already flying my small deltaV wing and takes the wing up like a rocket... V wing weighs in at 8.6oz and the Nifty weighs 9.1oz..
latest videos
24 inch Nifty with emax 2204 2300 quad motor 1 11march2017 (5 min 28 sec)
24 inch Nifty with emax 2204 2300 quad motor 2 11march2017 (7 min 54 sec)
24 inch Nifty with emax 2204 2300 quad motor 3 11march2017 (3 min 44 sec)
Mar 12, 2017, 09:28 AM
gpw
gpw
gpw's Avatar
Quite Nice Dave !!!
Re: Working backwards , we’re adding things till it flies ... or is “stiff enough “ ... attempting to save as much weight as possible (with what I have ) ... and would rather a slow motion version of your Nifty ... more like a "Yard Nifty” ... Now in the test gliding phase ...
Apologies , once we get this out of mind , we’ll build a proper Nifty (rocket) What started this idea was MS showed me a Tiny lipo he had acquired , with an impressive voltage delivery in a small LIGHT package ... I’d only want to fly something like this for a few minutes so wouldn’t need anything larger. ( as yet ) ... working up to it .. Why? ... because it’s so “Nifty” eh .... hahahaha
Ps. I did have a CF flat spar that would have fit perfectly behind the step , but it felt heavier than the bamboo ...
Mar 14, 2017, 04:45 AM
davereap's Avatar
also worth trying are strips of laminating film.. ruler width.. put on like the pallet strapping above and below the wing..they are light enough..
Ive used the strips on the leadfeather eppyak55 model instead of diagonal CF bracing, running strips down the fuz, stops the twisting..
shown in the pictures its difficult to see, but look for the shiny areas ..its used either side of the horizontal and vertical fuz, across the stabiliser and elevator. and a couple of other places..
what was an easily twisted fuz is now stiff enough..
Mar 15, 2017, 03:07 AM
davereap's Avatar
Ive given my nifty a motor change.. the emax 22042300 is off and a T2204-2280 is on..
the T motor definitely has a bit more thrust and the nifty will now go vertical , all be its slightly on the slower side..
note here.. the AUW makes all the difference as my deltaV with the same motor is the best of all going vertical...only 1/2oz lighter but has noticeably better...
I wonder what a high kv blue wonder might do.. they have more thrust.. so will be my next trial...
more videos for evaluation...
flight 1
24 inch Nifty with t2204 2280 quad motor1 14march2017 (3 min 28 sec)
flight 2
24 inch Nifty with t2204 2280 quad motor2 14march2017 (4 min 26 sec)
flight 3.. I forgot to remove the last bit of text... it refers to flight 2
24 inch Nifty with t2204 2280 quad motor3 14march2017 (3 min 12 sec)
Mar 15, 2017, 05:29 PM
gpw
gpw
gpw's Avatar
Still a Rocket ... But Very Cool Dave !!! ... we were hoping for something much more sedate for our Nifty LITE... waist high, 6-8 ft. away .... that may not happen no matter how light we get it ...
Mar 16, 2017, 03:54 AM
davereap's Avatar
If you build it light enough you can under power it... mine will fly at under 1/2 power fairly slowly..
perhaps I should try an extra light weight build for indoor flight, I havnt been in that direction with this design....
Time for a smaller one , starting with a 20" out of 3mm depron with an 1811 motor, 6A esc and small servos... I will knock one up..
Mar 16, 2017, 06:13 AM
gpw
gpw
gpw's Avatar
Thanks Dave, it’s a very nice simple design .... Fun !!!
Apr 16, 2017, 12:47 AM
davereap's Avatar
Here is a nice plank variation, by Thomas B.
a change of wing shape , central fin and a lower fuz has made a lot of difference..
Nieuport Geheimprojekt (1 min 49 sec)
Apr 18, 2017, 07:56 PM
Hi davereap. Have you ever tried a central fin on a Nifty? Just curious. BTW, I have built a full size Nifty a few years ago from $ Tree foam. I remember it to fly well. Planning on building a 24" next project. Bought some foam today:-)
Skip.
Apr 19, 2017, 04:50 PM
UP!
Pop.eye's Avatar
... a couple of month ago I've built the "Blank Plank". It looks really similar to Dave' s version!?
KFm 2, all 9mm depron, wingspan 1m, wing depth 0,34m, motor AL2830 v3 1300rpm/V, flying weight 517g with 3s 2200mAh.
Tom
Apr 19, 2017, 06:57 PM
gpw
gpw
gpw's Avatar
Dave , my flying buddy walked in, took one look , and said he had to have the EPP Nifty .. so i gave it to him .... What are flying buddies for eh ?
If you have kids, build these with them Gordon Johnson Scratchbuilt Indoor and Micro Models 26 Jul 08, 2005 11:12 PM
Simple current measurement with cheap multimeter StaalBurger DIY Electronics 14 Dec 14, 2004 12:43 PM
Plank With "Clark-Y-ish" Airfoil? Buzz_Man Flying Wings 94 Sep 24, 2004 03:50 PM
Simple series P51 with baby bee LevelUphill Fuel Plane Talk 1 May 19, 2003 06:18 AM
Build Wingo with PVA instead of Epoxy ? JensJakob Foamies (Kits) 10 Jun 05, 2001 12:50 AM
