Thread Tools |
This thread is privately moderated by [email protected], who may elect to delete unwanted replies. |
Mini-HowTo
Programming the Turnigy/iMax 9X
Thought I'd write this guide as the manual is a bit lacking...
First off: SWITCH ERROR!! This is the message that greets you when you power on the Tx if you have ANY of the switches in the on position. It boots up properly when ALL the switches are in the OFF position. Next: How the MENU works: Hold down the MENU button for about 1 second. Select your options with the UP DN buttons and a short tap on the Menu key. You save things with a short tap on the Menu button or cancel them with the Exit button. How to select and change the model name: Select 'Model Name' Up down selets which letter of the name you want to change + and - selects the letter to change it to. Hold down Menu to change the letter and immediately press Down to select the next letter. How to set up a Delta model: |
Bump for the New Owners
Here are a couple of links for you guys who have bought this TX and discovered It came without a manual.
http://www.skyrc.us/pdf/imax9x.pdf http://www.r2hobbies.com/manuals/rcps61207.pdf |
sorry but these 2 links is not valid anymore, i search and found this 2 version manual book for turnigy 9x
imax 9x https://www.box.com/s/cb3b695b7552a051d351 and Copter X https://www.box.com/s/28842be884bc568f61e6 (taken from http://www.hacksmods.com/2012/07/turnigy-9x-manuals/ ) |
Thread Tools | |
Similar Threads | |||||
Question | iMax 9X generally and 2.4ghz for the iMax 9X specifically: How is it? | JRexA | Radios | 30 | May 11, 2009 04:25 PM |
Discussion | Any info on iMax 9X 2.4Ghz radio? | John Kim | Radios | 1 | Jun 28, 2008 07:17 AM |
Discussion | iMax 9X 2.4 Ghz radio, made in China | John Kim | Radios | 0 | Jun 21, 2008 04:45 PM |
Discussion | Imax 9X Radio | andrechina2003 | Product Announcements | 16 | Feb 05, 2008 02:10 PM |
Programming instructions for JR 9x | duworm | Radios | 0 | Jun 25, 2003 11:23 AM |
