Jun 29, 2009, 03:31 PM
Dead Lipo
I made the mistake of not unplugging my 640Mah battery and ran it completely down. Now when I put it on the charger it comes up with an error saying "battery voltage too low" and won't charge. Some guys at the field said there is a way you can pull then back from the dead. Something about setting the charger for NiCd and charging for a few minutes then switching to lipo once the voltage gets up a bit. (I know....it sounds tricky and dangerous.) Anyone know anything about this?
Jun 29, 2009, 03:51 PM
Fully Sending It
Xpress..'s Avatar
Note: some lipos may still go on for numerous more cycles, whereas others may only last a few flights.
Chargers for NiXX and lipo are the same, just with lipo there is a cutoff voltage programmed into the circuit to prevent overcharge. NiXX cells are less sensitive to this so they don't have this circuit. You charge a lipo on the NiMH setting and at ~ 1/2C for a few minutes. The lipo will be fine as long as it's just a few minutes. Go too long and the lipo will get overcharged (see LipoSack demonstrations).
Jun 29, 2009, 06:30 PM
Space Coast USA
hoppy's Avatar
We could eliminate 50% of the posts in this forum by making a DEAD LIPO RECOVERY sticky.
Jun 29, 2009, 07:46 PM
Thanks guys. I plugged it in as a NiCd at .5 amp for probably no more than a couple minutes, then plugged in the balancer plug and set it for the proper battery type and it came back from the dead! Seems to be fine
Jun 30, 2009, 04:21 AM
7000mw of raw power!
rich smith's Avatar
I was thinking exactly that same thing. The noobs apparently do not like to read.
Alert HELP!!! Apache Smart Charger 2500 and dead Lipo mrbaseballny Batteries and Chargers 3 Apr 11, 2005 08:57 AM
Accu-Cycle Elite and trickle charging a dead Lipo Valid8r Batteries and Chargers 1 Mar 12, 2005 12:45 PM
dead lipo -- a complete mystery shams42 Batteries and Chargers 4 Jan 31, 2005 10:12 PM
Dead LiPo? root729 Batteries and Chargers 1 Jan 14, 2005 08:30 AM
Dead LiPo ? mrfirkin Batteries and Chargers 4 Dec 08, 2004 06:59 PM
