I got 5-6 more flights this weekend, I put on a apc 12x6 e and what power. It wold outrun the T-28 with the same motor and a 12x7 apc sport. Out climb it to! The P-51 is a little smaller than the t-28. As much as I enjoy scale flying the P-51, if something happens again I won't repair it. I'll move on. So if anyone wants to buy the broken fuse that is probably repairable(2 pieces), and a new wing from the second kit, PM me. Cover the shipping and about half of the wing and I'll ship the broken fuse and spare motor mount I have. Also a couple props that I never use and anything else I can round up. Rob |
Which ESC are you using with the 12x6 prop? Do you know how many watts you are pulling? I'm just curious because I'd like to prop up my P-51 but don't have a watt meter to make sure I'm not going to burn out the ESC. I'm currently running my old T-28's ESC plus the T-28 prop.
thanks! Quote:
Turnigy 40a Sentry ESC Turnigy Gold 35-36c 1100 motor Rhino 1850mah 40c APC 12x6e brake set for the prop. Max it would pull about 43 amps. The esc is good for bursts over 40a. I run this same motor/esc on several planes. It's been very reliable. I used a road hard and put up puffed Zippy 2200 20-30c (about 9 months old) this weekend. With this battery amps would probably be a little less than the 40c battery. Run 6-7 minutes and come down with 25% left. Couple runs I went about 5 minutes basically WOT the whole time, climbs, dives, hard pull ups. Lots of fun. I didn't have the cowl on because I forgot it at home but the motor was nice and cool, esc was warm+, battery was puffed! The battery would unpuff after it cooled, charge it up again and repeat! I'm hard on $15 batterys I know! 5 minutes of this is more fun than 10 minutes of easing around. I was most impressed by the very fast verticles. I usually run a 11x7 e prop which is no slouch either! For grins I came close to putting on a 13x6 I run on a Pulse Xt 25e. But it was the only spare I had and didn't want to risk it. There are some pics of my setup back a ways. Rob |
Yes folks, it appears our warbirds our under attack by Axis Geese & Hawks. (Que up the Twisted Sister tune "We're Not Gonna Take It!") |
Here is my mustang...turnigy 35-36 550 watt motor up front...du bro 2.5 spinner...hobby king super simple esc and turnigy 40 amp BEC...painted as man O war...This thing does at least 75-80 mph....w/ 10-5 APC.
Yes I did tape the hinges and ran a strip of tape around the stab also..LOL! Watts -532 Amps- 47.7 ESC is rated for 56amps burst so ill be ok.. Awesome fun..Check out my kitbashed corsair also...Dave from horizon hobby hope you see this...maybe next kit idea??? Spiteful PS sorry ill post pics after..lost them............ damn. |
Just received my airframe kit. Its going to be my first PKZ. Till now I was only building smaller warbirds – mainly GWS.
I would be grateful if someone could help me with the questions I have: 1. I have noticed that airlons are a bit stiff and wonder if Hitec HS45HB servos I planned to use will be ok ( 1kg @ 4.8v and 1.2kG @6V) ? 2.from my other models I have 2 types of batteries : Dualsky 1300mA 25c ( 115g) and FullyMax 2200mA 35C (193g). and 2 types of motors: TR 35-36C 1100kv and TR 35-30C 1100kv. I wonder if 1.3Ah cells with TR3530 (total 190g) would give reasonable performance or should I go directly to 2.2Ah cells and TR3536 (total 295g !). I intend to use props in the range 9x6(7,5) to 10x6(8) 3.what is default down and left thrust on RTF models ?[/INDENT] |
Ever have one of those days where everything you flew end up in pieces? Carguy had one of those days.
35-30 will pull this plane around fine, I have a 35-36c and its a screamer. the thrust angles are already in the firewall. |
Damn, that is some carnage! One hour on the sim for each crashed plane is the penance... and a hail Mary. That would be tough to yard sale that much of my fleet and still smile about it.
I was considering a 51 or a Corsair. Couple of questions about the 51. Why is it only three channel? No rudder. Secondly why does it not have a landing gear. I dont get it.
I like to fly it on the simulator - it seems to be the fastest. Interesting plane. Cadillac of the sky. |
Only the Corsair was my fault. I clipped a tree branch lining up on final. Saleen hand launched the F-16 at about a 85 degree angle and came straight back down. I was landing the P-51 with the gear on it and and Lintlicker yelled "go around" right when I was flairing for the landing. I gave it full power to get some speed up to go around and it did a nasty torque roll into the ground. All these planes were easily repaired are back in the sky.
Thread Tools | |
Similar Threads | |||||
Yippee! | Official Parkzone P-51 Owner's Thread Part 2 | Ferocious Franki | Parkflyers | 15 | Apr 02, 2014 11:22 AM |
Alert | Parkzone P 51 Mustang | peiviper | Electric Plane Talk | 35 | Sep 14, 2009 12:48 AM |
Official Parkzone P-51 Owners Thread | monitor | Parkflyers | 913 | Oct 04, 2005 09:02 PM | |
For Sale | Parkzone P-51 Mustang | argarre | Aircraft - Electric - Airplanes (FS/W) | 9 | Sep 20, 2005 10:57 AM |
Parkzone P-51 Mustang | wattman | Parkflyers | 453 | Feb 20, 2005 01:48 AM |
