Jun 22, 2009, 04:01 AM
The best solution for high-voltage MKS SERVO
HV 300 Servo Cyclic Exclusive support to the first leading 8.4~12V
Exclusive motor designed for high voltage applications
Outstanding precision combined with outlandish performance
Operating Voltage: 8.4V/12V
Operating Temperature Range: -10 to +60 Degree C
Operating Speed : (8.4V): 0.18sec / (12V):0.13sec
Stall Torque : (8.4V) : 26.9kg-cm / (12V) : 38.4kg-cm
Motor Type: Coreless Motor
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearings
Gear Type: Titanium Gears
Case : Aluminum-magnesium alloy shell
Connector Wire Length: 15cm
Weight: 2.79 oz. (79g)
Wire Length: 15cm
Dimensions: 40 × 20 × 45 mm
Deadband:Less than .001ms
HV 380 Servo RudderExclusive support to the first leading 8.4~12V
Operating Speed : (8.4V): 0.04sec / (12V):0.03sec
Stall Torque : (8.4V) : 7.3kg-cm / (12V) : 10.4kg-cm
Weight:2.36 oz. (66g)
Wire Length: 15cm
http://www.mks-servo.com.tw/servo-02.htm
MKS follow your heart & mind. We think. We do ! We made it !
Its the thing become true into your reality.
http://mks-servo.com.tw/productinfo/...80.767.787.jpg
__________________
MARK STAR Servo-tech Co., Ltd.
廣運科技 100% Made in Taiwan
[email protected]
Choices for High Voltage (10-11 Li) ESC [Propwash] Power Systems 0 Sep 11, 2004 06:26 PM
MGM TMM controller for high voltage setup? jetkkman Electric Heli Talk 1 Dec 04, 2003 06:21 PM
DC-DC converter for high voltage battery e-plane Takao Shimizu Radios 0 Feb 09, 2003 10:19 AM
best solution for difficult Deans tic Electric Plane Talk 3 May 13, 2002 06:08 AM
