Jun 22, 2009, 03:58 AM
Brushless Speed / Torque of challenges, the MKS 760μs with AVCS impression your idea
MKS BLS 980 Servo 速度 /力量 ...的挑戰.滿足你的快感極限
Operating Voltage: 4.8V/6.0V
Operating Temperature Range: -10 to +60 Degree C
Operating Speed : (4.8V): 0.04sec / (6.0V):0.03sec
Stall Torque : (4.8V) : 2.5kg-cm (6.0)V : 3.1kg-cm
Motor Type: Brushless Motor
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearings
Gear Type: Titanium Gears
Case:Aluminum-magnesium alloy shell
Connector Wire Length: 15cmWeight: 2.12 oz. (60g)
Wire Length: 15cmDimensions: 40 × 20 × 40 mm mm
http://mks-servo.com.tw/servo-01.htm
RC revolutionary change in technology products we made for your dream come true !!!
Speed/strength… challenge. Satisfies your pleasant sensation limitSpeed/strength… challenge. Satisfies your pleasant sensation limit.
__________________
MARK STAR Servo-tech Co., Ltd.
廣運科技 100% Made in Taiwan
www.mks-servo.com.tw
[email protected]
Jun 22, 2009, 05:28 AM
A man with too many toys
They need to make a high torque version for eCCPM.
Jun 22, 2009, 06:11 AM
https://www.rcgroups.com/forums/show....php?t=1068587
check this , thanks for your advance http://mks-servo.com.tw/productinfo/BLS-950.980.jpg
Jun 24, 2009, 11:37 PM
www.skyhobbies.com.sg
skyhobbies's Avatar
cool, very nice update...
I'm sure many have seen the other new servos at the recent SIME...
Jun 25, 2009, 01:11 AM
[QUOTE=skyhobbies]cool, very nice update...
Jun 25, 2009, 05:07 AM
Can someone convert the torque to in-oz for me? I forgot the conversion equation.
Jun 25, 2009, 06:36 AM
for example like this ...hope this can help it :
Stall Torque (4.8V):27.91 oz/in. (2.01kg.cm)
so 27.91oz/in : 2.01kg.cm=13.8855 oz/in = 1 kg-cm
Jun 25, 2009, 08:46 AM
very very nice but to big for a 450 size
Jun 25, 2009, 09:15 AM
Are you sure that’s correct. All my servos are way over 100 oz/in.
Jun 25, 2009, 11:46 AM
Aerofever.net
Albert_Moto's Avatar
For 450 / 500 size, u may use the MKS DS8910, The perfect tail~!!
Jun 25, 2009, 11:51 AM
please check this SPEC. its same like Futaba apply data futaba S9650 50.03/62.53 oz-in. (3.6/4.5kg-cm) check here http://www.spartan-rc.com/resources/servodb/servo.php or http://www.hobbico.com/radioaccys/hcam1000.html
MAYBE YOU CAN TRY IT BY YOUR SDIE http://www.onlineconversion.com/weight_common.htm
Jun 25, 2009, 11:56 AM
Aerofever.net
1kg = 35.27oz
1inch = 2.54cm
So, 1kg/cm = 1 x 35.27 / 2.54 = 14.055oz/in
Jun 25, 2009, 11:57 AM
Danger! Danger!
FrankW's Avatar
How much and where do I buy one from? I'm looking for a new tail servo for my T-rex 500 and would consider trying this one out if the price is right before dropping the cash for a Futaba BLS251.
-Frank
Jun 25, 2009, 12:13 PM
Aerofever.net
-Frank
You may use DS8910 for TREX 500.. 2.01kg/cm is enough for 3D flying!! Moreover, the stock TREX 500 tail servo board is reserved for Servo size like S9257 and DS8910. If you use the standard size servo like BLS251, MKS's DS760 or BLS980, you will need a TREX600 tail servo mount parts.
I am flying the Protos 500 with S9254 servo and will change to BLS980 or DS760 servo very soon!! I will test both . . .
Here is a T-REX 500 3D testing video with the DS8910.
500新配備測試 (2 min 18 sec)
How do I hook up two brushless speed controllers to one receiver and battery? dom Foamies (Kits) 1 May 01, 2002 02:48 PM
ikarus v.45 brushless speed controller FS iatkinson Aircraft - Electric - Airplanes (FS/W) 5 Apr 30, 2002 08:16 PM
Whats a good Brushless speed 400 ? d12bn Sport Planes 15 Apr 30, 2002 01:55 PM
Hacker brushless speed ctr connectors nimwegen Power Systems 12 Mar 13, 2002 12:51 PM
Hooking up a Jeti Brushless Speed Control to a Jeti Pashor 15/4 motor. HELP!!! Rob R Power Systems 3 Jan 10, 2002 07:37 PM
