This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Jun 18, 2009, 12:52 PM
Jack Crossfire's Avatar
Heat gun vs IMU
Using pitch & roll drift to estimate the yaw drift is a myth you've been busting for years. It didn't work with the IDG300, but that was a much bigger package.
Let's blast the IMU with the heat gun & see what happens. If the temperature changes slowly enough to keep them all matched, U can probably derive yaw drift from tilt drift. In flight, they emit different amounts of heat, they're blasted by prop wash & their heat capacities differ.
If U get tired of reading about 3DOF IMU's, U can give up & install an AK8976A from www.asahi-kasei.co.jp. That's a 3 axis magnetometer & 3 axis accelerometer on 1 chip.
Unfortunately, those single chip 6DOF deals R exclusively for phone companies like Apple. You're stuck with an HMC5843 for $20 & an ADXL320 for $8. That would double the IMU tag.
AUTOMATIC TAKEOFF & LANDING NOTES
For Vika 2 automatic takeoff & landing, U don't have a position signal until a minimum altitude is reached & U can't tell when the minimum altitude is reached without a position signal. Ramp collective & fix attitude, hoping the sonar field catches it above a certain level before it flies away. Get the starting position when minimum sonar amplitude is reached & engage position hold.
WTB Trim Iron + Heat gun ETrain Aircraft - Electric - Airplanes (FS/W) 0 Sep 20, 2002 11:48 AM
Heat gun and sealing iron Sylvain Aircraft - Electric - Airplanes (FS/W) 3 Sep 03, 2002 08:24 PM
FS-Bug Plan, Heat Gun, Sealing Iron. Dandi6065 Aircraft - Electric - Airplanes (FS/W) 1 Jun 02, 2002 05:11 PM
technique on using heat gun correctly ahab Power Systems 5 Jul 22, 2001 08:22 PM
iron vs heat gun dale331 Electric Plane Talk 10 Jul 18, 2001 09:33 AM
