This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Jun 11, 2009, 12:33 PM
Jack Crossfire's Avatar
Biggest etch ever
Going over the Walmart specials again, a spin copter would take buying lots of toy copters & finding out if any have enough power. There's no other way. $100 was the price of finding out 12mm brushless motors R too heavy to land.
The Havoc Cyclone looks like it might work if chopped up. Lift junk hardware first. Etch a single sided board with no voltage regulator. Single sided is lighter than double sided. That's July's budget.
Our double sided boards cost 2x as much & weigh 2x as much because they need 2x the etching board & the vias R too big. Their only advantage is the form factor & the wow factor for our Iranian readers.
SSME nugget 4 U
The answer is yes, the SSME has 1000 tiny tubes on the inside of the nozzle, not the hatbands U see on all the media photos. The outside rings R called hatbands & just keep it from falling apart. Didn't know this, so didn't get a high resolution photo of the tubes. Only got a wide angle photo of the nozzle.
The tubes R 1/4" in diameter on the aft end & shrink to pin size as they approach the forward end. Liquid hydrogen flows from the aft end to the forward end to keep the nozzle from melting. The tubes R braze welded to the nozzle wall. Finding leaks is real hard.
Easy Star thread #17, the biggest trilogy ever! jcosta Foamies (Kits) 501 Apr 08, 2005 01:26 AM
