May 21, 2009, 06:32 AM
Question
Removing residue of covering film from a composite surface?
Hi,
I have a 2nd hand Graphite 3.1m wing that was covered fully (over the carbon/kevlar D box and over the built up section). I know from numerous pictures that the original wing only covered the built up section and the D box was left bare.
So in an effort to restore the wing to it's old original self, I am looking at recovering the wing.
What is the best way to remove covering film residue from a composite surface? I figure that it has to be easier than removing residue from a wooden surface.
What should I use?
Cheers
Glen
May 21, 2009, 07:13 AM
ein flugel schplinterizer
seanpcola's Avatar
I've done this several times on similar construction. If it's the adhesive/color you are removing try various solvents. IIRC denatured alcohol worked well. MEK, acetone, laquer thinner should work fine also. I try to keep my rag damp but not wet. No reason to flood the area with solvent.
Sean
May 22, 2009, 07:56 AM
Thanks for that Sean,
I'll give those a go. I was a bit wary of using Acetone but I'll try that last. I think I'll try eucalyptus oil first (I use this to remove sticky tape residue and it works a charm), then methylated spirits to clean of the eucalyptus oil. OR just try the methylated spirits first before the eucalyptus oil. Denatured alcohol is also on my try list too.
Thanks again
May 23, 2009, 06:46 AM
seanpcola's Avatar
Just be sure to clean the are well with something that leaves no residue. I keep a can of Prep-Sol around which is used in the Auto finish business to clean a surface of all wax/oil. It comes in a variety of names.
Also, when I go to recover that type structure I paint on a little Balsarite (for covering) over the composite parts to be sure it sticks well.
May 24, 2009, 02:13 AM
Yeap I was planning to use balsaloc which is my favourite (I like it because it is water soluble, so not messy to sponge on and clean up)
May 24, 2009, 05:44 AM
seanpcola's Avatar
I've never tried Balsaloc. Sounds like a great product. Gonna do some checking to see where it is available here.
Discussion Any Tips on Removing Epoxy from Covering Film. jnm2512 Electric Plane Talk 5 Aug 28, 2006 12:32 AM
Help! removing film from blucor ff ctorres71 Pusher Prop Jet Models 2 Apr 05, 2006 08:26 AM
Removing covering film... orion1210 The Builders Workshop 3 Sep 03, 2005 01:21 PM
Removing trans film from a molded wing? DaleM The Builders Workshop 0 Mar 18, 2004 10:04 AM
Removing covering film cwalsh Electric Plane Talk 2 Jan 08, 2002 05:55 AM
