Prop Saver or Not Prop Saver ?
I just got my first EZ* along with a Tunigy HXT 2835 brushless motor and 6x4 prop. In determining the best way to attache the propeller to the motor, I was hoping for some input from the FPV community figuring you all would be by far the most experienced at knowing the pros and cons when considering this.
Thanks in advance... |
I would not use a prop saver on that setup.
You don't really need a prop saver since the prop is not out front where it could take a ground strike. Get a prop adapter, something like this... http://www3.towerhobbies.com/cgi-bin...&I=LXMSG3&P=ML |
No No No . No prop saver. You will regret some day.
See my 1st FPV Busybee lost its propeller in flight, initially without my notice. Luckily it glides and land safely because of the low wing load. |
| Similar Threads | |||||
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| Discussion | To Prop Or Not To Prop..... | dlt2859 | Electric Power Systems | 17 | Apr 23, 2009 11:16 AM |
| Discussion | To PROP SAVE or NOT to PROP SAVE, that is the question. | Bombay | Electric Power Systems | 22 | Jul 10, 2008 05:00 PM |
| Question | Prop adapter or not | globalarray | Electric Power Systems | 3 | Feb 04, 2008 07:52 AM |
| belly landing--prop saver or not? | darrell_f | Vendor Talk | 8 | Apr 21, 2004 01:14 PM | |
| Speed 280BB - direct drive or not? | Tyson | Electric Plane Talk | 9 | Jun 04, 2001 06:12 AM | |
