This thread is privately moderated by crxmanpat, who may elect to delete unwanted replies.
Jan 12, 2010, 05:50 PM
Foam abuser!
crxmanpat's Avatar
Not really. The extra weight just about totally negates increased performance. All it really does is give me about 1 more minute of duration.
On these 15-20oz parkjets using the 2212-6 motor, I really love using a Hyperion 3S 25C 1300 pack. It's light, but packs a real punch. Gives me 5 minutes of spirited flying, which is just about right for these (after that I start to get bored ).
Pat
Jan 13, 2010, 08:45 PM
Slow Flyer
Bombay's Avatar
Servo positioning.
Pat:
I see that you install your servos quite a bit forward of the spar...while other folks install theirs over the spar. Do you install them that far forward in order to angle over towards the aileron horn or for CG or other reasons?
Rob
Jan 13, 2010, 11:34 PM
Foam abuser!
crxmanpat's Avatar
Well, my thing is that I try to put them as far forward as possible for two reasons:
1 - I want to keep the servo wires forward as much as possible to keep them out of the prop.
2 - I usually have to put the lipo as far forward as possible to make the CG. Having the servos forward helps (a little anyway).
The control rods can be supported half way back to keep them from flexing.
Pat
Jan 14, 2010, 09:32 AM
Minister of R/C
RC4Tom's Avatar
Pat... You have some great points. I will have to consider during my next foamy build.
Jan 18, 2010, 08:43 AM
TheTrashMan's Avatar
is 25c better than 20c on a parkjet?
Jan 18, 2010, 03:36 PM
Foam abuser!
crxmanpat's Avatar
I think we got you covered on that on the F-22 thread.
Pat
Jan 27, 2010, 06:19 PM
would these be good on a park jet,for push rods?
http://www3.towerhobbies.com/cgi-bin...?&I=LXPJX9&P=0
Jan 27, 2010, 06:35 PM
Foam abuser!
crxmanpat's Avatar
Yeah, that would work, but it's a little bigger than what I typically use. I use:
DuBro Mini E/Z connectors (for the servo arm)
DuBro Micro E/Z Link .047 (or some other company's equivalent, I always seem to have some GWS leftovers on hand)
Control rods are just .047 piano wire for the bigger planes, and .039 for the smaller ones that you can get at the hobby shop, or at some Ace Hardware stores. And if the wire needs any bracing between the servo and control surface, I just use some spare servo arms and ream out the hole for the wire, then glue it in somewhere in between.
Pat
Jan 27, 2010, 07:14 PM
if i use the bigger ones will it be stronger?
Jan 28, 2010, 03:42 PM
Minister of R/C
RC4Tom's Avatar
The bigger aren't really necessary for the speed you will be flying. I have the mini ez connectors on a X-41 Depron Foam Jet that does about 115+ mph with no problems.
Jan 28, 2010, 03:45 PM
i mean the rod its self.
Jan 28, 2010, 04:10 PM
Slow Flyer
Bombay's Avatar
If it doesn't bend when you exercise the control surfaces then you are fine. If it bends, either use the pushrod guides that pat recommended or go with heavier wire. However, the lighter the better in this particular instance.
Jan 28, 2010, 05:23 PM
ok great thanks!!!
Jan 29, 2010, 04:26 PM
profilefan's Avatar
Whats the power setup you use to acheive this speed?
Steven
Jan 30, 2010, 09:55 PM
Minister of R/C
RC4Tom's Avatar
profilefan...I used a Don's Wicked 3000kv motor with an apc 4.1x4.1 powered by a 4s 2150mAh 20C battery.
Discussion What's the BEST FLYING profile pusher jet around? Tram Pusher Prop Jet Models 51 Sep 20, 2009 02:30 PM
Discussion F-4 profile pusher jet TeraHurtz Foamies (Scratchbuilt) 48 May 26, 2008 03:30 PM
Discussion Simple Profile Pusher Jet ? electriceye Pusher Prop Jet Models 1 Aug 06, 2006 02:39 PM
Discussion which profile pusher jet to begin with? MicroHeli-Nut Pusher Prop Jet Models 3 Jul 13, 2006 09:55 PM
Discussion New Larger Scale FMS F-14 Profile Pusher Jet ggunners Simulators 1 Mar 11, 2006 11:42 AM
