This thread is privately moderated by crxmanpat, who may elect to delete unwanted replies.
Dec 31, 2014, 06:10 PM
I Look, Listen, and Learn
Timbo383's Avatar
Originally Posted by ndfanatix
Hey there all,
I like the gray color on the foam board sold at staples and Wal-Mart. I was wondering of I could just leave the paper backer on the foam so that when I was done creating the plane most of the surface was already gray? I could then just touch up the white areas and be done. The weight of the paper couldn't be much more than the weight of painting the entire bird. I also would peel the areas to be glued. Just looking for any thoughts on this!
ndfanatix
I used to leave the paper on my planes because I liked the stiffness, but the paper is almost half the weight of the foamboard. The paint is about 1/4 to 1/2 of the weight of the paper depending on how heavy you apply it
Jun 27, 2015, 07:39 PM
My semi profile SU 37 tips...
Canopy lock....
Jun 27, 2015, 07:44 PM
Steering wheel servo saver...broke 2 new servos using pushrod...
Jun 27, 2015, 07:48 PM
Elevon type control...first using hot melt glue, covered in heatshrink, reheat to adjust... Done...
Jun 27, 2015, 07:51 PM
Use clear tape to prevent broken nose right on top of main steering wheel...
Jun 27, 2015, 07:53 PM
For heavy landing....
Jun 27, 2015, 08:08 PM
Timbo383's Avatar
Do the rubber bands work good on that steerable wheel? Interesting idea
Jun 28, 2015, 01:00 AM
Yes, the band just slip from bend wire in crash, saved the servo gear. I used a wooden landing gear before and now replaced it with a carbon rod, good in turning....
Jun 28, 2015, 03:16 AM
Steering....
Jun 28, 2015, 09:41 AM
Jer. 29:11
jeffsch's Avatar
Yan, great tips! Thanks!
Jun 30, 2015, 04:23 PM
Hinges technique....
Much better flying....
Jun 30, 2015, 04:38 PM
Foam abuser!
crxmanpat's Avatar
I like the two-layer hinge idea, especially when using a type of tape that has poor adhesive qualities on foam (such as packing tape). By using Blenderm, I didn't have any of the normal peeling issues like packing tape does as it is extremely sticky, even on foam.
Pat
Jul 08, 2015, 03:24 AM
PaulB's Avatar
I LOVE Blenderm (Leukosilk here in Germany). Super sticky and really strong, however, the textured surface doesn’t do it for me…..
Clear tape for the top (visible) surface over a dry layer of smeared on Por and small strips (1 – 2 cm long, 3 – 4 in total) of Blenderm on the bottom (chamfered) surface.
Strong as whatever (I have had the foam break away behind the joint before the tape gives), ultra free moving and weighs next to nothing.
Paul
Latest blog entry: Just To Say Hello.......
Jul 11, 2015, 05:42 PM
The servo gear survived, the rubber bands act like a damper, soften the crash impact...
Discussion What's the BEST FLYING profile pusher jet around? Tram Pusher Prop Jet Models 51 Sep 20, 2009 02:30 PM
Discussion F-4 profile pusher jet TeraHurtz Foamies (Scratchbuilt) 48 May 26, 2008 03:30 PM
Discussion Simple Profile Pusher Jet ? electriceye Pusher Prop Jet Models 1 Aug 06, 2006 02:39 PM
Discussion which profile pusher jet to begin with? MicroHeli-Nut Pusher Prop Jet Models 3 Jul 13, 2006 09:55 PM
Discussion New Larger Scale FMS F-14 Profile Pusher Jet ggunners Simulators 1 Mar 11, 2006 11:42 AM
