I agree, it doesn't look too bad at all.
Remember that these were designed to be combat wings so for many folks the blemish free look only lasts about 1 flight and then they'll be laying on tape and hot glue or whatever it takes to get them back up into the air quickly! Also, for many of us, this wing was our introduction to learning how to fly a wing so there were many crashes before we finally got the hang of it. As rhodesengr said, making sure the servos are well glued in is the important part. If they don't move you should be fine. Also, instead of purchasing the Du-Bro control rod guides you can simply use one of your extra servo arms to guide the control rod. Drill one of the holes out so the control rod slides through easily and then cut a slit in your plane and glue the extra servo arm into place. -Mike |
Great advice, thanks guys. I think once I get the control rod set I'll be much more confident.
Was flying brushless Zagi's back in high school ~10 years ago, def excited to get this going again. Found a Tx battery pack btw so will get some work done and report back. |
What you have done should work.
I use the staple guides even on my big planes and they work great especially when the rod is compressed when the servo is trying to push the elevons down. I like to cut the hole in the foam smaller than the servo and wedge it in then glue it. I have used a lot of different servos. It looks like you have the HXT900s or possibly the HXT500s installed. they will fly the plane but they do have fragile nylon gears that may not last. Right now the price of the MG90s is as low as ever. If you have any trouble with them trade them out rather than replacing gear sets. USA warehouse. https://www.hobbyking.com/hobbyking/s...strSearch=mg90 https://www.hobbyking.com/hobbyking/s...idProduct=9392 http://www.amazon.com/s/ref=nb_sb_ss...90%2Caps%2C220 |
The HXT500s will not have enough power for the size and weight of this plane if the plane is doing any aerobatics. The HXT900s do have enough power but will knock teeth off the gears with any impact.
Sorry you didn't get the other servos to start with. I have great luck with the MG90 and MG90S servos. I am glad the price is only $5. (The MG90 is slightly stronger) We used to use the Hitec 82MG servos but locally they are over $21.00 a piece. |
Wait hold the phone, just looked up an old email and I actually purchased:
T-Pro Mini Servo SG-90 9G Servo How will those fair? Also, are the videos on the first page still the best assembly method? Would like to rewatch and need to figure out wiring and just want to go with the most tried-and-true method. |
Those look like an HXT900 with a different sticker. |
ASSASSIN on the Prowl
I maidened the ASSASSIN today in 14 knot winds over here in Florida..more wind than I wanted but the wing flew... had a 5.25 x 6.25 prop on a Power-up 370 motor. I built the plane true to Lee's instructions...1300 3s battery and MG90 servos. Flew to trim and break in motor today...four flights..enough break in.
Now I have deepened and lengthened the battery hole so I can put in my 1800 50c batteries..I will fly it (easy) with a 6 x 5.5 prop on Friday and order some 6 x 4's...the 5.25 x 6.25 prop may be underpowering..not sure yet as I have not tested wattage yet.. This is a flying tank...now its time to find some prey |
I wanted to say goodbye for a moment. I unsubscribed to all of my threads having to do with RC airplanes. I had to, I've been starting my day with a cup of coffee, a fresh pack of smokes and my RC threads.
I've made real friends on all of these threads, that have helped me and informed me I've allowed myself to become addicted to being with you. It's going to be lonely for a while I know, but I must do this. You all have collectively taught me how to fly RC airplanes and I thank you for that. DJ.... A.k.A: kamikaze ace..."He Wares No Helmet! |
Here is a little better picture of Bill's paint job.
hmmmQuote:
hmmm
forgot to add, the 2nd pic is the aftermath of my lastest flight casualty. my fren assassin's prop hit the linkage so hard that it ripped my servo off its case. lol good thing only the servo needs replacement. thats the point of this plane. fly more fix less.... am i right?????
Thread Tools | |
Similar Threads | |||||
Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 3 | Sep 04, 2016 05:47 PM | |
WALLY WING...no fins...flies great!!! | gpw | Foamies (Kits) | 32 | Aug 31, 2016 08:21 AM | |
Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 6 | Jan 29, 2004 05:05 PM | |
Noob concept plane | Mikey C. | Foamies (Kits) | 5 | Nov 11, 2003 02:05 PM | |
It's a boat...It's a plane...no! It's flightship! | MrBungle | Electric Plane Talk | 24 | Jun 26, 2001 01:55 AM |
