The Clay Matthews Assassin
Seeing that the football season is about to start I thought I would style my latest Assassin after my favorite linebacker. Like the Assassin, Clay is indestructible, fast, agile, and has a motor that never quits.
Amazing wing theme!
But you installed wrongly the horns in the ailerons. You have to install it near the wing, in the edge. Take a look at the first page, in the Lee first steps and youŽll see. At this way it wont work properly. Regards! |
p.s.: I like the scooby doo also!
Friends,
WhatŽs the better final weight for the Assassin go unlimited vertical? |
It will fly just fine. He will have a smaller range of motion but it will be ok.
Good Dog!Quote:
Looks good. Go Raiders! |
Reason: Add Go Raiders!
As long as they're in solidly and there's the proper amount of movement (3/8" up and 3/8" down), then you'll be fine.
I've got plenty of throw in both directions. I wanted to put the horns a little further back than I did in my first wing. Took a nasty spill and actually tore the horn out of the aileron.
I'm hoping to get this baby up in the air this weekend. One thing I still need to add is a slot for my tiny camera. I got one of those thumb size video recorders from HobbyKing. |
https://www.hobbyking.com/hobbyking/s...g_0_10sec.html or these http://www.graysonhobby.com/catalog/...vo-p-1405.html same servo- works great! |
I agreeQuote:
Here is my second Assassin! This time I made it with just two pieces of covering film on each side. I looks much more clean and resistent. The bidirecional filament tape is under, also the motor mount plywood, glued. Next step is install the eletronics. I enjoy so much building this projects! What do you think?
anybody used Tesa tape for the build ?
I have this tape. 2" wide. http://www.tesatape.com/industry/pro...tesa_4579.html |
Looks to be the same as the extreme tape that can be found at Home Depot and other places.
We use generic bi-di fiberglass tape that works just as well as the Extreme tape. I'm sure the tape that you have linked works just as well. Look for the best deal. |
Thread Tools | |
Similar Threads | |||||
Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 3 | Sep 04, 2016 05:47 PM | |
WALLY WING...no fins...flies great!!! | gpw | Foamies (Kits) | 32 | Aug 31, 2016 08:21 AM | |
Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 6 | Jan 29, 2004 05:05 PM | |
Noob concept plane | Mikey C. | Foamies (Kits) | 5 | Nov 11, 2003 02:05 PM | |
It's a boat...It's a plane...no! It's flightship! | MrBungle | Electric Plane Talk | 24 | Jun 26, 2001 01:55 AM |
