Last One Down Variometer - RC Groups
This thread is privately moderated by trappy, who may elect to delete unwanted replies.
May 19, 2009, 03:46 PM
trappy's Avatar
Hi guys,
My first and probably only blog post will be a shameless plug for my new product. The first and only available Variometer developed specifically for FPV flight. Not sure what a Variometer is? Check out the video:
L1D Vario - FPV Acoustic Variometer (8 min 1 sec)
The variometer will let you stay up longer and learn to fly with what nature provides. Using a sufficiently big video battery, there is no limit to how long you can fly. If you're doing long range or high altitude flights, the variometer is a must to guarantee a safe return (if battery power is low, just look for thermals to climb to altitude and then glide home safely). Thermals are everywhere where there is sun. Real glider pilots use it to travel thousands of miles without any motor on their aircraft at all. And yes, real glider pilots all have variometers inside their aircraft.
The Last One Down variometer contains a super-high-precision barometric pressure sensor that detects altitude changes at 6cm (~2.3 inch) accuracy. Compare that to OSDs which gives you readings at 1m (3.2 ft) accuracy! The variometer checks you altitude 50x per second and decides after one second if the thermal you are in is suitable for climbing to altitude. All you need to do is wait for the beeps, and then start to circle.
For more information on the variometer please visit my website www.lastonedown.com. There you can find out how the variometer is installed, pricing and also I will post some instructional videos on to help you find thermals by "reading" your surroundings.
If you have any questions or want to purchase the L1D variometer, check my website for availability or drop me a PM.
Dec 11, 2010, 07:22 PM
i-fly-any-and-'s Avatar
sweet
awesome job on the flight and avoiding arrest.
one down two to go DanC High Performance 3 Jul 16, 2004 12:01 PM
Used Axi 28/20/10 brushless motor w/Jeti Gold 40 AMP Opto ESC, last one. bruff Aircraft - Electric - Airplanes (FS/W) 3 Apr 17, 2004 12:24 PM
Illusions- last one! jbc455 Humor 0 Jan 14, 2003 11:42 AM
YEEEEhEEEEEW! I got the last one! kepople Foamies (Kits) 23 Jul 09, 2002 12:57 PM
