May 19, 2009, 11:50 AM
Build Log
6mm Profile Hawker Hunter
Pusher Prop – Hawker Hunter
I got myself a copy of the "Quiet & Electric flight international" (May 2009) and it came with a free plan for a 3mm depron profile EDF Hawker Hunter...
So I thought – ummmmmm – I happen to have several sheets of 6mm depron doing nothing and a Purple Peril Brushless motor –
So as I have been building pushers based on Franks plans - I thought let’s give it a go and build this Hawker Hunter – but in 6mm depron and make it a pusher........
So here goes....
First thing I did was photocopy the plan – Then cut out the main fuse of the Hunter – I noticed that that the way the plan was designed the wings were cut out and slotted into the main fuse and then the profile sides glued on under the wing .
I did not want to do it that way so I decided that I would cut out the main fuse – and then split it down the middle – thus making a top and bottom half, s the Fuse sides and wings would be one part. (See photos)
I’ll update this build log again as soon as I have done some more and taken pictures.
Martyn
May 22, 2009, 08:44 AM
To build the all moving tail plane
The original was for a 3mm depron model but I am building a 6mm depron model , so some small changes were necessary
I used lollypop sticks and not 1mm ply for all my wooden parts on the tail plane
Steps were
Cut out the Depron parts (left, right tail plane and centre section)
Make wooden parts (right (with control horn and left tail plane and right, left centre section
Drill holes in all parts for 3mm Carbon rod
Test fit all parts (no glue)
Finally glue it all together so that the right and left tail planes pivot freely.
DSCF0325 (0 min 24 sec)
All moving tail plane for the Hawker Hunter (0 min 45 sec)
May 28, 2009, 05:09 PM
Here is the tail Plane fitted and in action...
Hawker Hunter - Elevator control Test - Under Servo Power (1 min 48 sec)
Jun 02, 2009, 05:28 AM
Today I decided to add the classic dog tooth to the wings leading edge, - and also made some Drop tanks for the hunter – these are a push fit and can be taken off for flight, if ok in flight I will glue them in place.
Motor mount made and test fitted to the airframe
Aileron horns fitted and servo location marked – on C/G line
Jun 19, 2009, 11:46 AM
burkefj's Avatar
Looks good Martyn, just like i would have done it! Looks good, should fly really well.
Frank
Jun 25, 2009, 02:32 AM
A few more pictures
Hawker Hunter with 400 motor Pete123 Power Systems 204 Feb 23, 2019 07:22 AM
Hawker Hunter? LawnDart Electric Ducted Fan Jet Talk 16 Nov 23, 2002 12:25 AM
Micro Hawker Hunter Cees Kraaijeveld Electric Ducted Fan Jet Talk 13 May 06, 2002 05:27 AM
Hawker Hunter(has anybody built this) ryan d. Electric Ducted Fan Jet Talk 5 May 02, 2002 03:33 PM
Micro Hawker Hunter Cees Kraaijeveld Electric Ducted Fan Jet Talk 4 Dec 30, 2001 03:31 AM
