May 21, 2009, 12:04 PM
Huge field, little tree... WTH
Danoman812's Avatar
Well, here are the results...
If flies straight... hahaha. Little too heavy and a bit underpowered so, I'm going to build another one that is a minature of the miniture version when I can find the time. I have been thinking of some ideas that will reduce the weight even more and going to put a different size battery and a different type of core foam. I'll let 'yall know how things go shortly.
I have to say, the wing build-up and the design is a really good one. I just need to get the weight down a bit and I know this will fly great...!!!
May 21, 2009, 02:56 PM
Jack
jackerbes's Avatar
Congrats on the successful maiden!
I think that makes you the current record holder for the smallest Divinity. What was the wingspan on that guy?
I can't work on stuff that small. It makes me crazy to even try.
Jack
May 21, 2009, 03:27 PM
7000 Ft up in NM mountains !
uphiearl's Avatar
I have lightened my wing by 300g so far by removing the paper ! I sure wish I'd have known to remove the paper BEFORE you put it together !
We are up to 509g now. Most of plane paper is gone...
May 21, 2009, 06:02 PM
Danoman812's Avatar
Hey Jack...
The wingspan is 16" @AUW of 20.5g so, I'm doing the figuring on a 12" and see what happens... hahaha. I bet this one will be a wild ride. I think I can beat that record by a BIG margin. My radio with battery (the 90mAH) is right at 6.8g. So, I think I should be able to keep it around the 13g to 15g AUW.
Hmmmm... this is a fun venture. We'll see if it goes nuts with torque roll... hahaha.
May 21, 2009, 10:05 PM
uphiearl's Avatar
I got all the paper off by taking the wing apart. I IS worth it. It weighed 509g with the paper on. Now its 123g with the paper off. What is in paper that's so heavy ? I also realize the hot gun glue weighs a lot. I do have gorilla glue. Is that better ? It is gorilla super glue impact tough formula.Is this the right stuff ?
BTW this is a 60" wingspan wing. Is the weight about right now ?
May 22, 2009, 08:45 AM
Jack
jackerbes's Avatar
I didn't weigh the foam Board before I peeled it but after peeling a 20" x 30" sheet weighed 71 grams or 17.04 grams/square foot. That foam is 4mm/.157" thick.
For comparison, Dow PB III FFF weighs 19.75 grams/square foot with the plastic coating still on it. And is usually 5.6-6mm/.220-.235" in thickness.
The foam board seems to recover completely from soaking with water. If I buy any more of that I'll leave it out in the rain for a day or two, that would be a lot easier then stripping it. Even with the help of the Awesome cleaner it was less fun than I usually like to have. :>)
Jack
Jun 07, 2009, 02:54 PM
So how did this turn out? I'm needing a diy fpv airframe pretty soon, and this looks pretty good.
Aug 18, 2009, 04:04 PM
meanbaby's Avatar
AP
will you be planning on releasing pdf file for D2?
i love the D1 and want to try built the divinity 2
-pete
Aug 18, 2009, 05:36 PM
Geaux Saints
Hopalong X's Avatar
Pete
I'm surprised he didn't post the plans already.
That would be helpful. Hint! Hint!
Aug 18, 2009, 08:54 PM
Father Francis, formerly Apach
Plans for the D2 will be assembled on Labor Day break, while I am home.
Thankyou for your interest,,,,,,
Working on other smaller projescts at this time while working on the rd. Stay tuned...... Good things to come.
ApachePilot
Aug 18, 2009, 09:46 PM
Geaux Saints
Hopalong X's Avatar
AP
Thanks. Will be watching.
Be safe overseas.
Aug 19, 2009, 03:55 PM
Jack
jackerbes's Avatar
I talked to ApachePilot this morning, he is going to get some info to me so that I can start getting some plans together for the Divinity II. It might not take too long.
Think of the Divinityh II as a 48" Divinity 42. But with two KFm strips and steps on both the top and bottom of the wing.
Jack
Aug 28, 2009, 11:26 AM
meanbaby's Avatar
yay!!!!!!!!!!
good timing too, smack my 42 inch divinity 1 few days ago as the wind picked up and my noob skills
-pete
Aug 28, 2009, 12:05 PM
Foam Av8r
RogueTitan's Avatar
Very nice looking wing
Congrats on the successful maiden.
Aug 28, 2009, 02:03 PM
pabmadi's Avatar
Hi, It's EPP or Depron? Anyone have plans off this great design?
Thanks.-
Schuebeler Vector II Build Thread Gordon Electric Ducted Fan Jet Talk 198 Jun 02, 2012 08:18 AM
Bitstream-II build thread bwanajim Electric Sailplanes 2 Dec 11, 2004 08:46 AM
FoamyFactory Pitts Challenger II Build Thread. Boss248 3D Flying 44 Aug 29, 2004 05:59 PM
Rave Taco II Build FINALLY FINISHED!!! Acer Parkflyers 10 Nov 01, 2003 10:20 AM
Flashback II Build Question edkoz Parkflyers 7 Oct 14, 2003 10:18 PM
