May 08, 2009, 05:22 PM
Gelei Imre
Gelei Imre's Avatar
Build Log
Parkmaster 3D Mini Depron Scratchbuilt For 15 Buck
Hi guys, just wanted to share a cheap and easy build that flies so great .....and everyone who sees it fly wants to know where they can buy one. My friend bought an original from Multiplex, and I tested it and was liked very much, I believed it I build one. I show the building step by step with much photos.
Very cheap and easy to building. We need only a half sheet 6mm depron, 1-1 pieces 2mm and 3mm CF rod, and 1 sheet (A0) vinil folie (cheap, use it for decoration).
For glueing I use UHU Por (UHU Creative in USA), and hot melt glue.
The Parkmaster Mini:
Wingspan 75cm 30"
Fuse lenght 75cm 30"
AUW 350g 12oz
The A4 and letter plans are in post#6.
Parkmaster maidenflight (1 min 1 sec)
Let's go!
May 08, 2009, 05:57 PM
Geaux Saints
Hopalong X's Avatar
Gelei Imre
Very nice!
As always.
May 08, 2009, 07:10 PM
fly it crash it fix it
flyn_brian's Avatar
Excellent Gelei Imre your plans always seem well thought out simple and well illustrated. Thank you.
May 09, 2009, 05:03 AM
Went to mow a meadow
frank48's Avatar
Hi Gelei,
nice plane, nice plans - it'll be interesting to see it fly
Cheers
Frank
You might like to put the pdfs in with yours!
Last edited by frank48; May 10, 2009 at 05:23 AM. Reason: modified pdf plans added
May 09, 2009, 09:13 AM
Gelei Imre
Gelei Imre's Avatar
Hopalong x, Brihoo2k,
Thanks!
Frank,
Many thanks for pdf-cutting!
May 09, 2009, 11:47 AM
AKA Don
Thank you for sharing this very nice looking plane. The proportions suggest it is a very precise good flyer.
I would like to see a video and learn about the motor, prop and battery used.
Also, is the wing just assembled in the air? Top and bottom sheets are flat and then just closed over the spar and take what you get for airfoil? I need to learn more about how this is done.
Don
May 09, 2009, 01:10 PM
very nice. I would very much to to see thing in flight.
May 09, 2009, 04:28 PM
scrapy scrapy doo.
roonroon's Avatar
Hello Gelei,
Thanks for the outstanding plans and very good pictures.
A picture explanes sometimes more than word's.
I would like to build also this beautiful plane as next, could you give some spec's about motor and batt??
Ron (the Netherlands)
May 09, 2009, 11:15 PM
plane obsessed
Cody WIlson's Avatar
Nice work- very nice plane!
May 10, 2009, 12:11 AM
is it just me, or does the motor look like it has a ton of down thrust?
May 10, 2009, 01:38 AM
shotibf109's Avatar
Hi Imi!
She is nice one! Cheap and cheerfull!! Do you know what is the best in this side? Here the guys can see the potantial in your planes and in you as well!! And maybe Mr Burt R. is here some where.
ZSolt
The tail heavy thing is not too big problem with her cos the original vas designed to hoovering not to fly.
May 10, 2009, 02:51 AM
scrapy scrapy doo.
roonroon's Avatar
Hey Gelei,
So the setup could be with a Brushless Outrunner 1540KV or 1611KV?
I think that's powerfull enough.
11.1v 3c batt.
Shotibf109: also here we (I) like this kind of building.
Cheap, simple and easy, that's the way of building scratch plane's;-)
Btw. Thanks for a quick reply.
Grtz Ron
Any plans for 15-40 size 3D planes? grampi The Builders Workshop 2 Jan 20, 2005 03:18 PM
Any plans for 15-40 size 3D planes? grampi 3D Flying 5 Jan 17, 2005 09:59 PM
My new Depron Yak for indoor 3D flypilot 3D Flying 7 Dec 05, 2004 07:19 AM
EPP or Depron best for 3D? Magne Foamies (Kits) 1 Aug 01, 2003 07:21 AM
EPP or Depron best for 3D? Magne Foamies (Kits) 0 Aug 01, 2003 01:50 AM
