May 06, 2009, 01:39 PM
Blade 400 anti-rotation bracket/guide
Hello all,
This seems real simple but when a helicopter part fight you from taking it out one has to ask a question. I cant remove the anti-rotation guide from the Blade 400. Both screws are removed and it is loose but short of using a pry bar it wont come out. Anything hidden holding it in.
Not so happy
Vista54
May 06, 2009, 02:19 PM
Excellence is Expected
MakMov's Avatar
Originally Posted by vista54
Hello all,
Not so happy
Vista54
according to the manual it looks like you might have to seperate the frame to get it out.
But I don't know that for sure.
May 06, 2009, 05:21 PM
I was fearing that. A very simple part with two screws in a easy to get to location now might become a headache. Thanks for the suggestion. I'll give it a try.
May 06, 2009, 06:00 PM
MakMov's Avatar
I don't own one so I cant say but the instruction show something that could be a sleeved pin into the frame sides.
It doesn't look like a standard Trex assembly.
May 07, 2009, 01:36 PM
I wanted to install the light weight metal guide. It comes with the bracket/guide and two screws. There are no other holes. I cant see how would be a complicated issue. I am going to try your suggestion you made earlier later today. Will let you know what I find.
Discussion TRex 450 Anti Rotation bracket? sgrim80 Mini Helis 7 Mar 20, 2007 01:04 PM
Discussion Trex anti-rotation bracket part bjaffee Mini Helis 2 Feb 23, 2007 05:30 PM
Help! Swift Metal Anti-rotation bracket- WHERE did I see it??? badbill Electric Heli Talk 4 Aug 08, 2006 12:19 PM
Discussion TRex SE assembly: anti rotation bracket bjaffee Mini Helis 2 Jan 11, 2006 06:21 PM
Discussion T Rex SE Anti Rotation Bracket Problems?? steve bisco Mini Helis 4 Dec 28, 2005 03:36 PM
