Apr 28, 2009, 03:31 PM
Help!
Help needed for Airboss 45 ESC
I am new to this ESC stuff. I bought a brand new Airboss 45 Elite ESC and 2814T/820 motor. I connected battery (2500mah 3S lipo) to ESC, ESC to motor, and BEC to RX. Then I turned the transmitter on, pulled the throttle stick down to idle position, turned the BEC switch on. According to instruction I am supposed to hear one tone from ESC but I didn't. Anyway, I get the power to my RX, but motor doesn't work. What may be the problem? Any quick help, opinions would be much appreciated.
Apr 28, 2009, 04:16 PM
Which transmitter and receiver are you using?
Apr 28, 2009, 04:44 PM
I'm using Futaba 7C FASST Tx and R617FS Rx. And yes, I reversed the throttle channel first as the ESC instructions say.
Apr 28, 2009, 05:18 PM
Can you connect a servo to the throttle-pins on the Rx to check that the throttle-stick operates the servo?
Apr 28, 2009, 06:06 PM
Yes, connecting a servo to throttle channel was the first thing I did, and it worked fine.
Apr 28, 2009, 06:38 PM
By the way, I've just checked the leadwires of the motor and measured the resistance of windings, all of them seems to be 0.2 Ohm. I guess motor is fine. But what's the problem with ESC?
Apr 28, 2009, 07:41 PM
Cumulus Altimus
FASTBEN's Avatar
you may have a OPTO ESC if so you need a rx pack try and hook up a rx pack then test if it comes on then you need a separate bec.
BTW you say bec to rx do you mean the servo looking wire from esc to rx?
Apr 28, 2009, 07:49 PM
Usual suspect.
Did you also trim the throttle channel all the way down to the bottom?
Apr 28, 2009, 08:06 PM
I don't think Airboss 45 is an OPTO ESC. And yes, when I say BEC to Rx I mean servo-looking wire from ESC to Rx.
I didn't trim the throttle channel. End points in Throttle channel is -/+ 100% as suggested by the ESC instructions.
Apr 28, 2009, 08:24 PM
Cumulus Altimus
FASTBEN's Avatar
it wont hert to hook up an rx pack.
ben
Apr 28, 2009, 08:25 PM
For Futaba, I find that you have to change the servo direction from normal to reverse for the throttle channel. Else it think you have the throttle at 100% when your stick is all the way down.
Apr 28, 2009, 08:27 PM
Cumulus Altimus
FASTBEN's Avatar
post #3
Apr 28, 2009, 08:32 PM
Ben: I will definetely try it first thing tomorrow (I left the gadgets in my office).
Chivy: I set the servo direction of throttle channel to reversed since instructions clearly say to do it so. Later, I also gave it a try in normal mode but nothing changed.
What are the chances that this bran new ESC is defective. Is there a method to check it.
Apr 28, 2009, 08:35 PM
If you have a servo/esc tester, you can-most folks don't.
Are the positive/negative wires properly aligned in the receiver? (I've reversed them plenty of times-old eyes!)
Apr 28, 2009, 08:47 PM
Yes, they are properly aligned. I also reversed them to see if it changes anything, but then I lost power to rx, which confirmed the correct polarity.
Well, unfortunately, i don't have a servo/esc tester either :-(
Discussion Help needed for 2 Mega and 2 Castle 80 ESC, they Don't run good together. kriptonic Electric Ducted Fan Jet Talk 20 Jun 27, 2006 08:46 PM
Help needed for rookie/ batteries? freddy Electric Plane Talk 5 Sep 12, 2002 04:18 PM
Help needed for replacement GWS IPS motor Willy Parkflyers 3 May 22, 2002 07:27 AM
help needed for picking a motor for f-16 gliderdude Electric Ducted Fan Jet Talk 3 Dec 01, 2001 06:47 PM
