Apr 08, 2009, 05:02 PM
Help!
Help Needed My attempt at building a Quad
Well I am tring to build my Quad.
I have it assembled but I am having issues getting it stable enough to get it off the ground. I am using a Airtronics RD8000 for now. If any one has any ideas on how to make this thing more stable please let me know.
Here are the parts I used:
1- mini-mix
4- 750kv motors
4- Super simple 50A ESC's
2-10X6 triple props cw
2-10X6 triple props ccw
4-PG-03 gyros
8" of sch 40 1/2" pvc pipe
4-1 1/2" pvc couplings
3-6" servo extersions
thin plexi to mount the equipment on.
For batteries I am tring different sizes from 2-2200ma in parallel to 2-4200 in parallel.
Here are som pics
Mark
Apr 08, 2009, 06:06 PM
OK
I think I found part of my issue. I noticed that the motors kept changing rpm. I disconnected my gyros and found that now the motor speed is constant. So it think my gyros are to sensitive. I have attached a picture of the gyro mounted to to a piece of neoprean rubber and still get the vibration.
Any suggestions???
Mark
Apr 09, 2009, 01:42 AM
capt's Avatar
Read on the tri-copter thread that those cyclones do not work well if at all. I have a tri with the same problem. The gyro's worked when I had them on a conventional airplane installation, so not sure if that is your problem but thats where i figure my problem is. The real GWS PG-03 is supposed to work great so they are not the same gyro.
Let us now if you figure it out!
Apr 09, 2009, 11:52 AM
Yes I guess cheap is not always the best way to go.
I am going to try a G-190. I will let you know how that works
Mark
Apr 09, 2009, 03:44 PM
I think 2S lipo's are not sufficient if your using 750kV motors. I-d suggest 3S or even 4S lipos. You need about 2x thrust to weight ratio and I don't think you'll be getting that on 2S with these motors and props.
Don't know what the maximum update frequency of these ESCs is. For a stable quadro you need ESCs which can be updated at least 150/s.
Also why spend significant amounts on separate gyros without any integration? You can probably get better results quicker by ordering one of the multicopter flight controlers such as the QuadroControl 2XS (only a microcontroler and 3 gyros, will allow using some normal ESC over PWM, but only if the ESC allows a PWM update frequence of 150/s or more but will also accept ESCs which are controled using TWI/I2C interface), the UAVP (separate thread in this forum), the mikrokopter (see the thread in the aerial photography forum), arm-o-kopter, X3D, draganflyer's controler as used in the 1000mm quadrocontroler in this thread, etc. Or participate in the Quaduino project in this forum.
Apr 09, 2009, 05:09 PM
Thanks for the info Arthur.
On the batteries, I am using 2-3s-2200 or 2-3s4200
I will check out the QuadroControl 2XS
Mark
Build Log Help Needed My attempt at building a Quad markeydoo VTOLs 1 Apr 09, 2009 04:06 PM
My first attempt at building and converting a Guillows to a RC plane gwong Scale Kit/Scratch Built 40 Nov 01, 2006 04:39 AM
Cool My attempt at a Spad - Could use some advice aeajr SPAD - Simple Plastic Airplane Designs 0 Dec 31, 2003 06:34 PM
My attempt at making a pilot flailing Scale Kit/Scratch Built 10 Jan 09, 2003 03:14 PM
Foam cuttin help needed... My pieces bend after they're cut... NetForce2K Beginner Training Area (Aircraft-Electric) 4 Jul 04, 2002 02:50 PM
