Apr 06, 2009, 12:29 PM
Jeanskydive's Avatar
Hawker Tempest Mk II
Hawker Tempest Mk II, wing span 46in., build from Ron Daniels kit, power with a Hacker A40-12S with 4S-3300 lipo. and 12X6 APC prop. Covering with solartex natural and clear dope, and mix color for camouflage paint. With this set-up be ready for a fast action. Have a nice flight Regards
Apr 06, 2009, 01:32 PM
Pro Hoarder
turbonut's Avatar
Hello Jeanskydive, Nice pics! You have pics of the MKII but your post says MKV.Are you building a MKV Also?
Scott
Latest blog entry: In flight
Apr 06, 2009, 05:16 PM
Tempest MK II
Yes Scott My mistake this is MK II , Regards Jean
Apr 13, 2009, 08:35 AM
Ron Daniels's Avatar
Looks Great!
Glad to see your Tempest is still prowling the skies of Quebec!
Wonderful photos! I think these are the best flight photos of a Mk II that I've seen....
How old is this plane now?
What's the weight down to with the LiPO's etc?
Do you ever fly it with your friend's Mk V?
Ron Daniels
Apr 13, 2009, 03:40 PM
Nice looking Tempest there. Are the different sized wheels for different field conditions?
Cheers Mike
Apr 13, 2009, 04:17 PM
Sabrejock's Avatar
Very interesting gear mounts. Do you put the next larger size of brass box stock in the wing? And do you ever have the gear stick to the plane after take-off? Tex.
Apr 17, 2009, 07:46 PM
Tempest
Yes larger size brass stock square in the wing block , some time i have to clean inside de brass stock with Q-tip. nerver get stock fall all time Regards Jean
Apr 18, 2009, 11:42 PM
Hi Jean,
How do you trigger the wheel drop?
Ron
Nov 12, 2015, 07:29 PM
Tempest MK-II
After 1 2 years of flying,. first one from Ron I build in winter 2004, I did some damage to is cowling,. so with 1/2 in., balsa wood I made a new one , nex step wiil be 3/4 oz. fiberglassing and paintig, and ready for another mission!! This model fly so beautifull in worthy to made is new one. Cheers.
Nov 12, 2015, 07:49 PM
tempest MK-II
Originally Posted by Ron Daniels
Hi Jean,
Ron
Simpley gravity fall foom is square tube mont into is maple wood, glue into is main wing spar. Cheers
Nov 12, 2015, 10:21 PM
Full scale or 1/8 scale
Shell shock 2's Avatar
The mock radial engine nose weight is genius.I'm going to put a plate
like that in the nose of my Typhoon. Thanks for sharing
Nov 12, 2015, 11:08 PM
Yes Sir, alluminium , also verry solid and easy to remove fronm cowl , only three screws . Cheers
Nov 13, 2015, 12:33 AM
Hawker Tempest MK-II
Fiberglassing cowl done , sanding and primed and paint nex. Cheers
Nov 14, 2015, 12:19 AM
Hello , cowl install sand and prime ready for is final painting and ready for action again., Cheers
Nov 14, 2015, 09:40 PM
Paint and rivets done , nex reinstal the motor and ready for action again. Cheers
Off Site Skyshark RC Hawker Tempest MK-V - 45 (Kit) edygert Aircraft - Fuel - Airplanes (FS/W) 1 Feb 19, 2009 02:50 AM
RWDRC Tempest Mk V Build Doc Data Scale Kit/Scratch Built 17 Aug 18, 2004 11:42 AM
Photos of Swedish Tempest Mk V in action Ron Daniels Scale Kit/Scratch Built 2 Jun 12, 2003 03:38 PM
Hawker Tempest Mk II painted (finally) Ron Daniels Scale Kit/Scratch Built 30 Apr 09, 2002 02:58 PM
Hawker Tempest Mk V finally painted Ron Daniels Scale Kit/Scratch Built 6 Apr 01, 2002 12:16 PM
