Oct 07, 2011, 04:35 AM
Registered Loser
PeeMax's Avatar
Originally Posted by Vantasstic
With MOST installations the DL receives power from the Tx, no secondary battery needed. Some Tx's don't provide power via the trainer port, thus something different has to be configured to power the DL. So in short, it's all according how you hook up your DL to your Tx that determines if it'll be powered or not.
thanks but I was asking about the receiver in the plane
Oct 07, 2011, 08:26 AM
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Silly me, misread what you were asking. The Rx is powered just like you would any other receiver...normally for a 5v Rx battery/ESC BEC/External BEC. The older Rx's weren't rated for 6v, the newest one is. I'd stick with a standard 5v input just to be on the safe side.
Oct 07, 2011, 08:50 AM
Focus-Fixers for DJI Goggles
imagebuff's Avatar
Same setup as per DX7 plug. It works on the DX7 but not DSX9. Power to TX and
the light seems fine but just cant get it to work. The motor just goes beep beep beep. It works good when with my DX7. Anyone can help on this?
@Mer78
Try sticking a dummy plug into the trainer socket. That's what I have to do on my 9503.
Chris
Oct 07, 2011, 08:58 AM
@Mer78
Chris
That is the way I did my 9503 too. I used a male servo plug coming out of the radio battery compartment and put a female servo connector on the DL. I then took an old pair of headphones and cut the connector off and shrink wrapped it with the extra DL wire out of the way. To use DL I set my model number and turn the radio power switch off, plug the servo connection in and plug the headphone jack into the trainer port and wait for the DL green light.
Oct 07, 2011, 10:30 AM
ptuxbury's Avatar
So I just received my Futaba 8FG Super, which I ordered specifically to use with my DragonLink. I was disappointed to find that the DragonLink will not work with the Futaba in 12-channel mode. I can only get 8 channels to work.
So, besides the 9X transmitter, is there a list of transmitters that can take advantage of all 12 channels of the newer DragonLink receivers?
Tux
Oct 07, 2011, 01:03 PM
12 Channel Receiver pin outs
Anybody know what the pin outs are for the new dragon link 12 channel receiver.
Is the ground the pin the one close to the pcb.
Paul.
Oct 07, 2011, 01:15 PM
ptuxbury's Avatar
Yes, ground pin is the one closest to the PCB. V+ is the middle. Signal is the one furthest.
Oct 07, 2011, 02:15 PM
When in doubt, throttle out...
badlands's Avatar
Easier to visualize...
Oct 07, 2011, 03:02 PM
Vantasstic's Avatar
Paul.
The newest 12 channel has end pins. In this case, the top of the board is the side with the SMA connector. The pins on top are Signal, middle is Voltage, bottom is GND.
Oct 07, 2011, 06:00 PM
badlands's Avatar
Yea as Van said...
Oct 07, 2011, 06:52 PM
JettPilot's Avatar
Originally Posted by badlands
Yea as Van said...
Hey,
I have seen that RX before, it was one of my favorites
Oct 07, 2011, 07:07 PM
JettPilot's Avatar
This thread is nearing 1000 pages, which is awesome for us, but not so awesome for people looking for information about Dragon Link, there is just too much to digest. So we are moving the Dragon Link thread to the new Dragon Link thread, click on the link below. John will be closing this thread shortly, but we will contine in the new one as always
https://www.rcgroups.com/forums/show....php?t=1518533
Oct 07, 2011, 07:09 PM
Team Basement-RC
Tracks's Avatar
Umm... you have to include a link for that to work, Mike.
Oct 07, 2011, 07:39 PM
I LIKE WAFFLES....
SENTRY 62's Avatar
Mike - you have a PM.
Oct 07, 2011, 07:56 PM
I LIKE WAFFLES....
SENTRY 62's Avatar
Clear your PMs Mike.
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14481 May 19, 2020 02:21 AM
Discussion Need help selecting wireless,long range (100Km), light-weightcamera system. gaurangvador Aerial Photography 11 Feb 23, 2010 06:33 AM
Discussion Has anyone tried the new Long Range UHF system? djdaveq FPV Talk 4 Dec 06, 2008 01:38 AM
long range radio system suggestions?? oracle_9 Thermal 15 Aug 09, 2008 10:44 AM
easy to use wing/airfoil program? i-fly Power Systems 1 Nov 27, 2001 06:51 AM
