Mar 29, 2009, 09:21 PM
Need guidance with set-up for 2 batteries
Am in the assemby stage and want to use (1) 4s A123 battery to power the motor, and a seperate battery to power the servos. What is the correct way to do this? I looked for an existing thread, but didn't find one, but if you have a link, I would appreciate receiving it.
Mar 30, 2009, 03:42 AM
An itch?. Scratch build.
eflightray's Avatar
If the ESC has BEC, then it needs disabling if you intend using a separate power supply for the receiver and servos.
Again, if the ESC has BEC, disconnect the red, (center wire) in the connector to the receiver. You could cut it, but the better way is to lift the tiny plastic tag that holds the connector in, pull the connector out and tape it back. That way if you need the BEC facility later, it's easy to replace.
Mar 30, 2009, 04:09 AM
eflightray's Avatar
I have just created some pictures if it helps anyone.
Mar 30, 2009, 05:30 AM
Nice clear picture sequence, eflighray
I would just add that, if your ESC is an opto one, which doesn't have a BEC in it, you need to keep the red lead connected in order to power one part of the opto ESC.
Your receiver battery then goes to any spare channel in your receiver, or can be Y-leaded to share a channel if you have none spare
Discussion Help Needed with Set Up for Blade 400 and Futaba radio Blue Jacket Mini Helis 6 Nov 10, 2008 11:02 PM
Help! set up for 2.5m sailplane fishdude Electric Sailplanes 9 Mar 16, 2006 06:55 PM
Need help on set up for the shockflyer. santi 3D Flying 24 Feb 02, 2004 03:31 PM
Need help on a brushless set up for my zagi Scar13 Foamies (Kits) 8 Mar 24, 2003 05:42 PM
