Mar 22, 2009, 02:21 PM
Night Flyer
muppet61's Avatar
Build Log
Dual patch antenna, to fly all around you.
As you know, to have a good video signal range, you must use a patch antenna.
But with this antenna you can only fly before you and you can't fly behind you.
THE low cost SOLUTION:
Make a dual patch antenna.
(3 min 33 sec)
http://translate.google.fr/translate...hl=fr&ie=UTF-8
first test flight:
Mar 22, 2009, 03:46 PM
plus vite plus loins
Funjet2008's Avatar
How have you balanced ohm ?
I can't see over the 2nd patch connected to the first
Mar 22, 2009, 04:02 PM
Night Flyer
muppet61's Avatar
i dont modify the electrical caracteristic.
i just take the front plate of the second antenna, and i put it on the back of the first antenna.
on this photo you can the
1: the original antenna
2: the original antenna mounted on fatshark
3 - 4: Dual patch antenna
Mar 22, 2009, 04:16 PM
Funjet2008's Avatar
ton fil du 2eme patch, il est connecté ou ??? le patch est relié par quoi ? y faut ben avoir un contact quelque part !
Mar 22, 2009, 04:23 PM
Night Flyer
muppet61's Avatar
sur la deuxième patch je ne prend que la plaque avant, le reste de l'antenne où il y a le câble je ne l'utilise pas.
Cette plaque je la monte à l'arrière de la première antenne ce qui me fait 3 couches au lieu de deux.
La partie centrale où il y a le cable, la plaque avant d'origine, et la plaque arrière récupéré sur la deuxième antenne patch.
on the second patch I takes only the front plate, the rest of the antenna where there is the cable I do not use it.
This plate I mounted at the rear of the first antenna that makes me 3 layers instead of two.
The central part where the cable, the original front plate and back plate recovered from the second patch antenna.
Mar 22, 2009, 04:26 PM
Lynxman's Avatar
Interesting. It seems to work well all around you.
The ending was funny.
Mar 24, 2009, 04:50 PM
Night Flyer
muppet61's Avatar
Test of some antenna on the fatshrkk google.
Tx 10mw 2.4ghz
(5 min 22 sec)
Mar 31, 2009, 03:26 PM
Night Flyer
muppet61's Avatar
other video
(0 min 14 sec)
My last flight with the antenna:
Discussion How do you charge enough batteries to fly all day? Bing44 Batteries and Chargers 12 Feb 24, 2008 02:45 PM
Do you fly Glow around Cleveland, OH?? BrunswickOH Fuel Plane Talk 6 Sep 13, 2004 06:04 AM
What's your favorite all-around, fly anywhere plane? thomer Parkflyers 56 Apr 09, 2004 03:36 PM
What is a good all-around electric sailplane??? Woody Electric Sailplanes 9 Jun 05, 2001 04:41 PM
All Around Best ESC dezflyer Electric Plane Talk 13 May 21, 2001 12:32 AM
