Mar 05, 2009, 06:23 PM
Paul Bonati's Avatar
Help!
RCM&E Zulu E free plan (february 2009)
Hi !
I really like the plan. I have this motor:Tower Pro 2409-12, the recommended motor is E-flite Park 480.
I really don´t understand to much about electric motors. I would like to know if my motor could fly this plane . I do sport flying (simple aerobatics).
Thanks, Paul.
Mar 06, 2009, 06:05 PM
Is it possible to use these motor ?
Paul
Mar 06, 2009, 07:21 PM
Fully Sending It
Xpress..'s Avatar
I think you meant to click on the "new reply" button, rather then the "new thread" button. The new reply button lets you reply to a thread you're reading in. The new thread button starts a completely new thread.
Mar 08, 2009, 05:46 PM
These are the airplane characteristics: (published in RCM&E as a Free Plan febreuary 2009)
Model Type: Sporter
Wingspan: 48 inches
Fuselage length: 36.6 "
All up weight: 3 lb
Motor used: E-Flite Park 480 / APC 10 x 4.7
Esc Used: Tornado 40 A
Battery used: 3 cell 2100 Li Po
I would like to use this motor set up:
motor:Tower Pro 2409-12A
esc : 40 A
prop: 10 x 6
Is it possible.
Thanks, Paul.
Mar 30, 2009, 03:16 PM
Any HELP out there ???
Paul.
Mar 30, 2009, 04:48 PM
ben199's Avatar
Paul.
Hey,
Here is a build thread for this model
http://www.modelflying.co.uk/forums/...s.asp?th=24106
Their free plans are a lot of fun and their build forums are helpfull, the designer even answers questions on the forums
I've built 2 planes from their magazine and the help via their website/forums was great, I learnt a lot
-Reuben
Mar 30, 2009, 05:29 PM
Ben, thanks for your anwer. I will try in this place also as you suggest
But my problem is that I really not understand well about electric engines. I have the engine detailed before and I would like to know if it could handle this plane.
Are you going to make also ?
Thanks again, Paul. (sorry for my bad english)
Mar 31, 2009, 12:36 AM
ben199's Avatar
Hi Paul,
I'm not sure about your motor? does it have a KV rating, and a recommended prop size and an idea on what size model it suits? this would give you an idea.
I was thinking about building it but I have one kit to build and one arf still in its box aswell The zulu is a nice looking plane.
Your english is fine
-Reuben
Mar 31, 2009, 12:45 AM
ben199's Avatar
Features:
Using larger and ferromagnetic make it more powerful than 2408 series motors.
2409-Series Motors for indoor sport-flyer, trainer-flyer,F3A and park-flyer models;
The high performance outrunner design features, All motors include hardware pack which features prop adapters, mounting hardware.
Specifications:
Type: 2409-12
Weight:65g
Output Axis:M3
Current:8.2A/12.7A
BATTERY: 3-4 cells Lipo
KV:1570
Io:1.2A (10V)
Internal resistance:0.065Ω
Max Efficient Currency:9A
Recommended Working Currency: 7A - 20A ( Efficiency higher than 75% )
PROPELLER: 8x4 APC/9x4.5 APC
Comments:
Recommended Applications:
a. 3 cell Lipo: APC 8*4SF 11100RPM 10V 20A Thrust 805 gram ( Air pressure 76mmHg/25 degree)
b. 3 cell lipo: 9X4.5APC-E 9900RPM 10V 23.8A Thrust 960 gram ( Air pressure 76mmHg/25 degree)
I just checked the spec's for your motor, I'm not an expert but I would think you need a lower Kv motor that you can spin a larger prop with, after reading the Zulu-E spec's they state its an under 1.4 kg model, reading the motor spec's they state 805grams when using an 8x4 prop and 960 grams of thrust using a 9x4.5 prop.
your best bet would be to find a motor that has the same spec's as the park480 motor. The park 480 has a Kv rating of 1020kv.
I hope thats not too confusing, there maybe someone else on here that might be able to help.... I'm also a beginner
-Reuben
Mar 31, 2009, 06:07 AM
Reuben:
Thanks again for your efforts !!!
Maybe you are right and maybe I would need a better electric power set-up.
Paul.
Aug 12, 2018, 06:05 AM
Is there a source for these free plans at less than their typical plans price of 19£ or similar pricing.
The Zulu E is a nice design, sorry I missed buying it at the news stand.
David in NE TN
Help! looking for RCM&E May 2005 for Fizza free plan maxy333 Australia 3 Mar 02, 2017 09:24 PM
Splash-E Free plans in FLY RC jimsp Waterplanes 78 Jun 22, 2007 03:58 PM
Discussion Cierva Autogyro Free Plan RCM&E john whitehead Sport Planes 1 Jan 10, 2007 04:21 PM
Fly RC's Free Plan for the Race-E Scrambleon Parkflyers 3 Jan 05, 2005 09:40 PM
Cool Piccolo conversion to Bell 47 free plan Twmaster Electric Heli Talk 1 Feb 01, 2002 05:14 PM
