Mar 04, 2009, 08:03 PM
AZ Outback
Robert Burson's Avatar
Contest
X5J eXtreme March 21,22 Sign-Up
Welcome, back for the sixth year.
Introducing new classes: that will run with the X5J eXtreme rules except without a handicap on motor type.
X5J 1.5M class Wingspan 1.5M limit, motor small outrunner (bells depth limited to 17mm), maximum weight 452.8g or 16oz. Maximum lipo nominal voltage 7.4.
5min flight task. Flight time - motor time. 30 point landing tape.
X5J America class
Power 4s A123 cells, minimum weight 2.0Kg or 70.7 oz. No motor handicap.
I will score these classes seperate from the X5J eXtreme, and place X5J America class, in the final standing.
>>>HOPE YOU CAN ALL MAKE IT OUT FOR THE eXtreme<<<
Remember all photos of new ships and OLE favorites are encouraged.
Please read all rules, if you have not flown this event before, everyone else, will note they are unchaned from 2007.
X5J eXtreme Rules:
1. Any electric powered sailplane can enter this contest.
2. There will be three 10minute flights. One point per second of flight time is scored and, one point deducted for each second over the 10minute-flight time. Maximum points possible 600. Round to the closest second for your flight time.
Example 9minutes 50seconds = 540pts + 50pts = 590pts
10minutes 4seconds = 600pts 4pts = 596pts
3. Motor run time is unlimited but subtracted from the flight time.
Example, 600 flight pts - 19 motor run pts = 581 total round pts.
4. Landing points to be measured from the center of the landing circle, to the closest part of the plane. For each meter from the point subtract 3 points from 30pts . See attached file for table.
5. Motor handicap: brushless 95%, brushed Cobalt and brushed car motors 75%, Ferrite 45%, and outrunners with a 28mm or less bell diameter and 17mm length 68%, Speed400 30%. The X5J America Class will have no motor handicap. Actual motor run rounded to the closest second. Then multiplied by the motor percentage. Round this calculated value to the closest 1/10th of a second.
Example Cobalt motor time 34 .6seconds = 35seconds X 0.75 = 26.25seconds = 26.3 seconds
6. You may restart your, motor as many times, as needed, but on the second motor start, you may not add landing points. A second way of stating this rule. If you start your motor after launch run of the motor, you will not receive any landing points.
7. Your flight is limited, a single dawn to dusk flight day of your choosing, during a 48 hour period.
8. Any type of battery cell is legal.
9. Temperature Factor to be added to total flight score. See the attachment for the temperature table.
Timers still need two stopwatches, this was easier then I thought it would be. Work out a signal with the pilot, if he is going to restart the motor. (I.e. "restarting...on...off")
This is the simplest way of scoring I have been able to come up with.
Flight time - closest second
Motor run - closest second
Calculated motor run - closest 1/10th of a second
Landing points - see table Rule #3
To compete: Please list your plane, gearbox, prop, cells and type, weight, and any other interesting facts, pictures are always welcome, to this thread.If someone else, not on the Web would like to fly with you please list him or her, on or by March 20th.
To all who enter,
The Best Soaring
Robert
Mar 04, 2009, 08:15 PM
AZ Outback
A few E ships from around the world.
Mar 05, 2009, 11:09 PM
what makes that thing go
ploof's Avatar
I'm in, the weather has been getting alot better around here lately.
For the 1.5 I hope to fly the 14oz. E Blaster 2 W/ ESC Jeti Spin 11, 2208/20 AXI motor, 12x13 RASA prop, and Thunder Power 2s 910mah battery.
For Extreme I hope to fly the 16oz. E Blaster 2 W/ ESC Jeti Spin 22, 2212/12 AXI motor, 12x7 Robbe prop, and Thunder Power 3s 910mah battery.
Fingers crossed for good flying
Ploof
Mar 06, 2009, 05:21 AM
ohmite's Avatar
Count me in too. I'll be flying the Omega 1.8 with a Scorpion 2215/12x8/3STP2100 or the HiAspect with a B40/9L/4.4:1/15x10/3sTP3300 (if I get it fixed in time).
Good flying to all
-Eric
Mar 06, 2009, 07:51 AM
turn, turn, turn.
Kenny Sharp's Avatar
I'm in.
Unbelievably, I was unable to fly electrics for all of February.....there was simply too much icy snow on the ground.
I not only missed this Postal, but the Australian Postal (AEFA) as well.
I flew my DLG exclusively, as I am able to hand catch it, or land it on the Airport driveway.
Good news!....The snow won't last forever!
I am really looking forward to this months' electric soaring.
I'll be in with my E-Topaz.
Mar 08, 2009, 07:26 PM
the kitty litter of rcgroups
rdwoebke's Avatar
Ken,
I have been flying a lot of DLG too. In fact, I worry I will miss this thread since I have not been as active in this forum recently. I had a bad feeling today as I was flying my e-Paragon for the first time in 2009 that perhaps the postal was this weekend.
Seeing I did not miss the March Postal I'm in with either my electric Allegro Lite, assuming I did not kill the battery last time like I sort of worry I did or my Paragon or perhaps even my CDROM plane.
Ryan
Latest blog entry: Supergee wing mount pylons
Mar 08, 2009, 08:03 PM
I'm in again for the March X5J event. Depending on the weather, I'll fly either a 1.9 or a 2.5 M Art Hobby e-sailplane with a direct-drive, brushless inrunner power system, and a 3S 2200 lipo pack.
It has been very windy in my part of the world over the past many days. I hope that changes by the X5J weekend!
FF
Mar 10, 2009, 11:01 AM
I need a bigger garage...
ajreynolds's Avatar
I'll give it a go again in the 1.5M event. Chrysalis HLG-e, Scorpion 2208-30, 2S lipo, 13oz AUW.
It will be a glider day for me. Our club is having their monthly LMR event that day too.
Andy
Mar 12, 2009, 08:51 PM
AZ Outback
Looks like some good weather for the weekend, so the AVA mini B40 F5F, 18 x 10, with 2s Neu 4100's. Hope everyone has great weather, it has been a long winter. Not sure what Mcramer will be flying.
The Best
Robert
Mar 14, 2009, 10:44 AM
Super Secret Agent
CV580drvr's Avatar
And I'm hosed again, with 2000 miles between me and my models.
Good Luck, and Great lift to all!
CV
Mar 18, 2009, 09:59 AM
To bad it was not last weekend. You could have thermaled a pattern ship on either day.
I'm still building my new airplanes, so I'll fly my speed 400 model again. 4:1 GB, 11x8 prop, 8x600AR.
Mar 19, 2009, 03:44 PM
rdwoebke's Avatar
I flew the Allegro last weekend so I think I'll fly the Allegro. A20-20 clone, 2S 1320 lipo.
Ryan
Mar 20, 2009, 01:11 AM
I will fly my own design with MVVS 3.5/960, 3s1600.
Jan
Mar 20, 2009, 12:30 PM
Neil Stainton's Avatar
I'll try to fly one of my models, Super AVA-e, Supra-e, or Simply the Best.
Neil.
Mar 20, 2009, 03:19 PM
I'm in with my Castor RES Medusa 28x40 4.3-1 gear 14x9 prop 2200 thunder power battery auw 40 oz.
Don
Discussion X5J eXtreme July 14th/15th Sign-up Robert Burson Electric Sailplanes 43 Jul 18, 2007 11:52 AM
Discussion X5J eXtreme May 5th/6th Sign-UP Robert Burson Electric Sailplanes 72 Jun 30, 2007 09:35 PM
Discussion X5J eXtreme April 14,15th Sign Up Robert Burson Electric Sailplanes 84 May 01, 2007 08:49 PM
Discussion X5J eXtreme July 1 - 4th Sign-up Robert Burson Electric Sailplanes 66 Jul 26, 2006 06:17 AM
F5J eXtreme March 19/20th Sign-Up March 18th Robert Burson Electric Sailplanes 82 Apr 07, 2005 04:37 PM
