May 30, 2009, 05:44 PM
May 30, 2009, 06:25 PM
Flying...Pushing Air Down
sr71fan's Avatar
Antonio,
You're not invading the thread; you're making it more interesting!
Post away!
Gary
May 30, 2009, 07:34 PM
Lets break some props :D
joseico90's Avatar
Cool
TJ
You're welcome, are you building anything yet?
Gary,
Thanks, I've tested the blades and had fun, I'm just getting the video done, I'll be back soon.
May 30, 2009, 08:25 PM
joseico90's Avatar
Today's Video,
Antonio.
https://www.rcgroups.com/forums/show...2#post12351493
May 31, 2009, 08:25 PM
Antonio, no I am not building yet. Still waiting on the CF for the rotors and shaft. I have been replacing sheet rock in my basement the last couple of days after replacing the leaky hot water tank.
However, after doing some more autogyro surfing, I do wonder why as a first autogyro that you don't see a stiff rotor with the coning built in like in this video. Gary, again I don't want to take away from your thread either so it my be better to ask this in a new thread.
https://www.rcgroups.com/forums/show...&postcount=109
Jun 01, 2009, 06:04 AM
joseico90's Avatar
That is some great video, never seen it before, I have sent him a message in Spanish hoping he'll get back to me with more info.
A coaxial rotor like that could be fun too TJ, it looks pretty stable and simple to make, I might put it in my "to try" list.
Here is a pic of my micro gyro with some coning built(bent) in.
Antonio.
Jun 01, 2009, 07:06 PM
joseico90's Avatar
Hi Gary,
I hope you're doing well,
here is "something I did earlier today ,
https://www.rcgroups.com/forums/show...3#post12365219
Antonio.
Jun 04, 2009, 02:08 AM
sr71fan's Avatar
New Photos
After a few days fighting that bully Flu bug, I was able to go out and enjoy some almost-calm weather this evening. Decided to take still shots for a change of pace. Still having too much fun.
Gary
Jun 04, 2009, 09:06 AM
joseico90's Avatar
Wow, Beautiful shots Gary!!
Love the ones with the orange tone sunlight!
Nice, Yours flies with the fusselage almost horizontal, unlike mine,
I think it's because you have more aft tilt on the rotor, it's a two blade, and your blades flex a bit more than mine, I used 10 degrees only, I must try one day.
I don't mind it that much because it comes to land already "flared" nose up!
I believe it has to do with Asymetrical Lift. (due to the stiffness of blades and hub)
You got that one pretty well sorted out Gary!
Antonio.
Jun 09, 2009, 03:13 PM
sr71fan's Avatar
Auditorium Autogyro
I snuck off to the dark auditorium during our SPEF fly-in last weekend. What fun! The room is almost as big as a single-court gymnasium. It has a stage at one end, and sloped bleachers on both sides.
There's a good crash at the end of the video. My battery dumped as I was about to climb over the bleachers.
Gary
Auditorium Autogyro (5 min 26 sec)
Jun 10, 2009, 09:33 AM
joseico90's Avatar
Nice one Gary!!
I'm glad it didn't brake
Same thing happened to me while hovering with a foamy at the park..batt went flat ...it fell down vertically from 2m, just a small crack on the Depron elevator's moving part!
Jun 25, 2009, 01:58 AM
sr71fan's Avatar
New Rotor 40 Inches Diameter
I wanted to test a larger rotor on my AG3-2, so I had to decrease the rear tilt of the shaft in order to clear the tail feathers. This is a 40-inch two blade rotor made the same way as the smaller ones with 3mm Depron and a 2mm carbon rod on the leading edge.
What a difference! This is going to be a blast indoors! I have some balancing and tracking work to do first, though. You'll see in the video...
Gary
Testing Larger Rotor on Autogyro (1 min 51 sec)
Jun 25, 2009, 04:00 AM
Closed Account
Hi sr71fan,
That was a real pleasure to watch your AG3-2 in the calm evening air, well done Sir and thanks for sharing, Cheers,
regards Al
Jun 25, 2009, 05:28 AM
Suck it and see
Norfolk Flyer's Avatar
Hi Gary,
Beautifully stable flight and you managed a really short landing in what looked like still conditions.
Are you still using 3mm depron blades with a 2mm CF L/E?
Once you have balanced out the shakes it will be a dream!
Best wishes,
John
Jun 25, 2009, 06:09 AM
PeterO_UK's Avatar
It's flying very nicely! I'm looking forward to seeing it flying indoors.
PeterO_UK
Looking for TurboCAD 2D 6.5 Zoom The Builders Workshop 22 Dec 01, 2006 01:04 PM
Yippee! My wife got me a digital postal scale today. My moth is 6.5 oz w/ no battery! The Other Dave Parkflyers 1 Feb 08, 2002 11:37 PM
Aeronaut 6.5x4 or 6.5 prop for Zagi 450T ? freq Foamies (Kits) 3 Oct 25, 2001 07:36 PM
Will a 6.5-4 prop work with a direct drive Permax 480? Ryan Nau Power Systems 2 Apr 29, 2001 12:43 PM
