Feb 19, 2009, 06:21 PM
The Wombat's Avatar
Arado AR-234 Semi-Scale Build
My brother (RudeDog) and I have been talking for over a year to joint build the AR 234. We will utilize a foam (construction/building insulation) cross section method for the fuselage, hotwire pulled foam wing and depron tail feathers. We intend to use the nacelles and power system from a GWS Me-262 kit…GWS BLM005A (3900Kv)motors, 22 amp speedies and a 3 cell 2050 mAh 20c battery. I used a 3 view drawing uploaded in cad and traced the line work and engineered the plan from there. Wingspan is approximately 44”…target weight is around 33 oz…if my calculations are correct that will yield a 23oz/sq ft wing loading. Rude & I have kicked around the idea of using a trolley similar to the one used on the early models…we’ll have to see about that.
Feb 19, 2009, 06:43 PM
I wonder if one of these could be converted into a slope version.
Feb 19, 2009, 07:00 PM
The Wombat's Avatar
attack...Rude & I plan to test glide this bird to nail down the CG...I'll let you know...
Feb 19, 2009, 09:50 PM
EDF rules... :)
AirX's Avatar
Nice work, I like this kind of construction. Good luck with the model.
Eric B.
Feb 20, 2009, 05:38 AM
The Wombat's Avatar
thanks Eric...
Feb 21, 2009, 06:58 PM
CAN WE MAKE IT FLY?????
rudedog's Avatar
Just a small note Wombat is the Brains of the outfit.....All I have are the LOOKS
Feb 21, 2009, 09:40 PM
The Wombat's Avatar
Lol
Mar 07, 2009, 12:23 PM
newcomer's Avatar
any progress. this is one of my favorites.
Mar 08, 2009, 09:36 AM
The Wombat's Avatar
Yep...thanks for asking newcomer...I'll post some pic's later today
Mar 08, 2009, 04:19 PM
The Wombat's Avatar
Owl Emblem
after a little research...
Mar 09, 2009, 11:19 AM
rudedog's Avatar
Man that thing is starting to look like a 234
Build Log 1/10 Semi-Scale EPP Mini Cassutt – Free Plans, Build Guide & Video firetrappe Foamies (Scratchbuilt) 777 Oct 30, 2017 05:39 AM
Cool COZY Mk IV Canard Semi-Scale Foam Scratch Build Steven Wong Foamies (Kits) 242 Mar 25, 2015 03:17 AM
Mini-HowTo Eindekker Semi-Scale scratch build with Videos, pictures **neons** Foamies (Scratchbuilt) 11 Nov 12, 2008 03:30 AM
Hydrofoam XXX Semi-scale- build thread dougmontgomery Foamies (Kits) 6 Aug 22, 2008 04:00 PM
Build Log sopwith camel semi scale build gizmo_22 Foamies (Kits) 4 May 19, 2006 06:58 PM
