This thread is privately moderated by kpriddle, who may elect to delete unwanted replies.
Sep 07, 2014, 05:05 AM
hlsat's Avatar
RCM 1-2A Basic Trainer.
Type Model RC Sport.
Wingspan 38.75in.Highwing.
Engine Glow Cox BB .049
Control 2 - 3 channels.
Designer Dick Tichenor.
Magazine RCModeler Dec.1978.
The plan found Here by JohnAV8R.
https://www.rcgroups.com/forums/show...&postcount=140
The Original scan Article found Here
http://pulling-gz.blogspot.gr/2012/0...?view=flipcard
Sep 07, 2014, 05:13 AM
hlsat's Avatar
RCM Basic Trainer.
Wingspan 50in.Highwing.
Engine Glow Veco .09 - .19
Control 4 channels.
Company Bridi Hobby.
Sep 07, 2014, 10:43 AM
hlsat's Avatar
Lil Toad.
Wingspan 30in.Delta.
Engine Glow .10 - .15
Designer A.L Reuther.
Magazine RCModeler Feb.1969.
http://pulling-gz.blogspot.gr/2014/0...?view=flipcard
Sep 07, 2014, 01:35 PM
Team Fearless
~SnApRoLl's Avatar
Mini-Sukhoi
Mini-Sukhoi
Engine .049 - .099
Plans and Article are in the same zip file.
Sep 07, 2014, 09:59 PM
Team Fearless
~SnApRoLl's Avatar
ACE Littlest Stick
Littlest Stick
by Fred Reese
from RCM
November 1975
20in span
Engine .010-020
Originally was built for single channel rudder only control but can be converted to 2 or more channels.
The PDF file includes the article and tiled plans.
This is the model that the LaStick by Dave Fritzke is based on.
Sep 07, 2014, 10:58 PM
Team Fearless
~SnApRoLl's Avatar
Bipe Stick
Bipe Stick
Engine .074
Sep 08, 2014, 01:17 AM
Promoting Model Aviation...
Murocflyer's Avatar
Would it be possible to get some link to companies that sell the engines in post #1?
Frank
Sep 08, 2014, 11:42 AM
Team Fearless
~SnApRoLl's Avatar
Frank
I didn't see the engines you were referring to in Post #1 but if you're looking for COX engines and parts, specifically .049's, you can to www.coxengines.ca
They offer reproductions such as the Babe Bee, The Black Widow, the Golden Bee, the Texaco .049 as well as some specialty and limited edition engines. They also have a great selection of parts as well.
Shawn
Sep 09, 2014, 04:12 AM
Murocflyer's Avatar
Shawn
That what I was wondering. For those looking to get started in 1/2A airplanes and look for the sticky, post #1 should have links to places where you can buy engines from. Can the post be updated to reflect those links? The OP appears to be still around on RCG.
Is Cox the only one that makes/sells these small engines? Are they the preferred brand?
Thanks for the engine info, I appreciate it.
Frank
Sep 09, 2014, 09:19 AM
Norvel is about the best IMHO. There is a .049, .06, .074, .15, .25 .40 and .40 gasoline version. NV engines is what they are called now. the .074 is a nice strong runner, depending on the plane you have in mind. http://www.nvengines.com/index.php?o...mart&Itemid=65 There is also and AP (ASP) .06 that is still available, mine doesn't work well, but some people have good luck. They also have an .09 and a couple of .15's that are fine, the blue head .15 being the best of the .15 'value' size. http://www.hobbypartz.com/aspengines.html Hobby King carries both Cox and some ASP stuff too. I guess they are a sponsor here. Bernie in BC Canada supplies the Cox NOS stuff if you want to deal directly.
Sep 09, 2014, 12:38 PM
Andrew0820's Avatar
I would also suggest that you visit http://www.exmodelengines.com/ . Matt is located in the US and carries much of the stock that COX International carries. I have dealt with both Matt and Bernie -- both are fine individuals and both offer excellent service.
Sep 09, 2014, 01:16 PM
Murocflyer's Avatar
Awesome! thank you gentlemen! This helps a ton. I have flown gas and nitro, but never an IC this small. Should be a lot of fun.
Thanks again for the help.
Frank
Sep 09, 2014, 03:08 PM
Team Fearless
~SnApRoLl's Avatar
You can also get glow engines ranging from 1/2A and up to a 1.80 from Hobby Partz at great prices.
.061 http://www.hobbypartz.com/72p-ap061a.html
.09 http://www.hobbypartz.com/72p-ap09a.html
They also have a .12 and two 15's
.12 http://www.hobbypartz.com/72p-12a.html
.15 http://www.hobbypartz.com/72p-ap15a.html
.15 http://www.hobbypartz.com/72p-s15a.html - I have this one. It's a re-branded Magnum XLS-15. It has a much better price than the Magnum and it performs just as good!
Shawn
Sep 09, 2014, 06:10 PM
Send lawyers, guns and money
ahrma_581's Avatar
Originally Posted by hlsat
Quickie.
Wingspan 38in.Highwing.
Engine Glow .09 - .15
Control 3 channels.
Designer Fred Reese.
Magazine RCModeler Dec.1972.
Anyone familiar with a very similar design, that appeared sometime in 66-67 timeframe? I built something for single channel, with an identical wing (two sheets of 1/16 x 6, flat bottomed airfoil) and similar box fuse, I think from plans in RCM. I used a Cox .049, altho I don't remember what was called for.
Sep 09, 2014, 07:54 PM
Perchance somebody has the plan/article from RCM for the 1/2A Hornet using a TD 049, mine met its demise pulling out from a tophat manoeuvre and an electric version may be more suitable these days. I was using a Logictrol 2 channel brick Rx & servos in mine
Alex
"1/2a" rob dahlbo Beginner Training Area (Aircraft-Electric) 10 Jul 12, 2021 06:22 PM
House of Balsa 1/2A Stealth Sport --> EP? MiL Sport Planes 8 Dec 20, 2009 12:46 PM
Elexico (1/2A Texico) plans/kits rht0930 Electric Plane Talk 3 Apr 07, 2009 06:07 PM
Help! 1/2A Ducted Fan - Project Skyray jetpack Fuel Jet Talk 5 Oct 22, 2008 04:15 PM
Converting a Sureflite 1/2a Cub to electric ARCHER7153 Foamies (Kits) 2 May 21, 2001 12:05 AM
