Another E3d takes to the Skies!
1 Attachment(s)
Well, the weather has finally cooperated here in the midwest, and I finally had the chance to get out and try a couple new planes, one of which is my E3d/christmas present from my wife. Its been done, ready to go for a few weeks, just waiting patiently for good weather.....and yesterday and today it finally arrived.....
First flights yielded the results I had hoped for, a fun smooth flyier with no trim required. This is going to be a GREAT plane to fly.........:D Darryl |
1 Attachment(s)
Here's another one,
1 Attachment(s)
By the way, did I mention that this is a removable wing E3d? Thanks to all the posts from you Ezoners for the info. I used the slide-off/plug in wing mod., and have some additional tips and photos for anyone interested.....just let me know. The end result is a 38 oz. airframe and flying weight of 58-60 oz with 10 cell 2000 or 2400 bats. that dissasembles fits neatly in car or workshop. Once again, thanks to the e3d ezoners and all the posts for refernce.
Darryl ;) |
Darryl,
I like it. I like it a lot. The clear canopy really makes it look nice. I wish I had done the removable wing on mine back when I built it. Oh well, the wings off it now. :( Nice landing picture. --Paul www.oldschoolrc.com |
Darryl nice job!:D stefanP
Very Nice bird. Did you make your own canopy?
Nice!
Darryl:
Great looking E3D and a VERY nice covering scheme. You should have no problem with orientation with that contrast, and the checkers really look cool. I like checkers: https://www.rcgroups.com/forums/atta...&postid=741243 Keep it in one piece as you wring it out. Gary |
Patrick H,
No, actually, the canopy is the back 75% of a regular canopy I had laying around for another project. I kept the front part for something else down the road. Can't throw anything away!!:D Darryl |
Looks great !
I'm going to rebuild my seriously mashed E3D and the easiest way is to make it into a 2 piece wing. Could you please post a few details and pics of you set-up. I know it's been covered before but there are about a million E3D posts to sift through ! BTW, Is that an MD 80 in your avitar? Thanks |
Congratulations on you E3D. I like the checkerboard. Please post pictures of your removeable wing. Thanks for posting your beautiful plane.
Kelvin |
Thanks for the replies guys, I've been working all weekend, and go back today, so I'll get the pict.s you want on line asap(Wed.)
747drvr, yes, a Silver s-80, with red white and blue stripes!! Its still a great job, even with the airlines in such pain. Darryl:( |
Thanks Darryl ! I'm looking forward to seeing your conversion.
I agree it's a great job and wouldn't want to do anything else but things are changing ! Our management wants to cut 650 million dollars in labour costs and I'm sure I'll have to make a contribution... |
1 Attachment(s)
Well, while I cant give you the quality that Kelvin provided in his post, I'll try and give you my version, at least the steps required to do this conversion for the two-piece wing E3D.
The three main threads I used for research were: John Thompson's Removable Wing E3D My E3D Removeable Wing Modification Building and Flying an E3d I would like to thank those thread starters, Neil Stanton, CloudyIFR, and Kelvin, as well as all that posted to them for all the excellent info. I am going to try and follow the building instructions for the E3d, and note where I made alterations. As always, if anyone has any questions feel free to ask. I have added a few photos, but since I am new to building reviews, I did not get all the photos I would have liked, so written descriptions will be necessary for some steps. Construction Manual, Step 1. Leave the airfoil cutouts in the fuse sides. I actually left them in, and using a sanding block to sand the sides, forced some balsa dust into the cut marks, then dripped some thin CA around to seal them in place. I just used some regular 1/16 sheet for wing tips later. There was also a little space at the trailing edge of the die cutting that I just filled in with scrap. I then used one rib to mark the position of the opening for the pass-thru spar joiner. I simply laid the rib on the fuse side and aligned it with the cut-out, and marked the position of the spars. Then I removed the rib and connected the lines. You should have marked a rectangle the same size as the spar joiner. The “John Thompson’s Removable wing E3d” has a good photo of this. Carefully cut this opening at this time. I was not too concerned about the exact fit, as this is just the opening for the joiner, and will not bear the load. |
1 Attachment(s)
The following photo shows the backing plates I used for reinforcing the holes in the fuse sides, as well as the crutch assembly. On these pieces, I was VERY careful to make the openings exactly the same height and width as the spar joiner as they will be the alignment tools for the spar joiner. I also made the spar joiner at this time out of ¼ “ sq. spruce and ¼ X 1” balsa. Since the pieces for this were 36” long, and I only was going to use 24 “ of it, I saved the 12” cut-off, and used this for all the assembly and trial fittings, as it is easier to slip the wing on and off this shorter piece.
1 Attachment(s)
| All times are GMT -5. The time now is 12:03 AM. |
