Dancing Wings FD12 Windrunner DLG
25 Attachment(s)
I have bought a new kit to build in bad weather days. I have choice version with servo, cover foil, and transport bag.
In five day from order, I have received my FD12 kit. Very quickly. Some pictures from unboxing and checking the content of kit. |
First step
12 Attachment(s)
I prepared the work surface for half a wing.
Then I cut out all the pieces. |
Second step
6 Attachment(s)
Removing the rest of the fixings in the board. That's all for today, after a longer break. I hope to finish it by spring ...
Now it's ready to start assembling ... |
A half of wing - begin
18 Attachment(s)
I started assembling a half wing.
One problem that arose: the rib slots did not match those on the plan, reaching the tip of the wing to be equal to the thickness of the rib. I corrected this of course, so that it matched the plan. A black ball for the manufacturer! |
A half of wing - continue
5 Attachment(s)
I also glued the main pieces of the wingtip.
15 Attachment(s)
Continue with step 21 and 22 from "manual" - see the pictures.
I use for glue carbon road and glass pieces epoxy 30 minutes. Carbon sheet 0.5 mm x 520 mm are not in my kit ! Second black ball for manufacturer ! I will replace with 0.5 mm carbon road x 520 mm, from my personal stock ... |
13 Attachment(s)
Continue with step 23 and 24 from "manual" - see the pictures.
Attention to details, please. |
14 Attachment(s)
Step 24, and 25 ...
17 Attachment(s)
Step 26 ...
Bonjour ... Nice to see an other beautiful assembly - Regards to you ... We will follow your adventure with this balsa light DLG experience
The other half of the wing
15 Attachment(s)
Same error between the plan and the laser cut parts... Be careful...
No comments, pictures speak. |
The other half of the wing - next
15 Attachment(s)
/Another error in the central support of the ribs.
A laser cut, which had no purpose and which decreases the resistance of the wing. I corrected it, but the manufacturer still gets a black ball ! You can see it in the pictures. I had to use a stiffener to fix this problem. |
17 Attachment(s)
I continued working on the half wing ...
Until the newly glued parts dried, I started working on the fuselage ... |
10 Attachment(s)
I worked on the two wing halves.
I glued some more pieces to one, and while I waited for the glue to dry, I sanded the tip of one half of the wing. I'll probably have to insist. I also tested the joiner for the wing dihedral. It went in hard, I had to sand it lightly. I'll glue it in at the end. And the first weighing of the wing halves, one with the tip sanded, the other not yet, hence the difference. |
| All times are GMT -5. The time now is 11:50 PM. |
