RC Groups
RC Groups
        Discussion Transport case kit for Introduction/inside F5J
#1 popad Feb 25, 2022 09:56 AM
7 Attachment(s)
Today I have received transport case kit for Introduction/Inside F5J.
On short, in 4 minute you can see my week work.
Transport Box For Introduction F5J glider (4 min 24 sec)
#2 popad Feb 26, 2022 04:42 AM
15 Attachment(s)
I weighed the package. Everything weighs about 5 kg.
Manual in german, but google translator can do it now for document, and I translate in english. Only some "doubler" was "Doppler" :).
Cutting, grinding, matching ...
#3 popad Feb 27, 2022 01:13 PM
15 Attachment(s)
Today I started reading the manual and trying to see if everything fits. I really like. It's ok.
If the plywood had been perfectly flat and not slightly curved, I would have taken the second box.
The kit gives everything you need until the last screw needed for assembly.
I prepared everything to start making the necessary joints in the next few days.
#4 lucdus Feb 28, 2022 02:53 AM
Hello Popad, we follow your transportation box build up ... I will try to find the link of this box
#5 popad Feb 28, 2022 03:14 AM
Sorry, link in messenger :).
#6 popad Mar 01, 2022 08:07 AM
14 Attachment(s)
As I find in printed manual that I received with the kit, I make reinforcements from leftover material 4 x 68x 50 mm and 3 x 45x50 mm. (In pdf manual that I have downloaded, this missing.) I like to have all pieces before begin glue and mount.
Then I do first two step from manual. Glue with thin CA, sand, and begin step 3. It's a little difficult if you don't have a table board of 1,5 meter and many clamps.
Now waiting some hour to dry first side.
#7 popad Mar 01, 2022 12:51 PM
5 Attachment(s)
All sides of half of box are waiting now to dry ... All fit perfectly.
#8 popad Mar 02, 2022 08:00 AM
19 Attachment(s)
Working ...
#9 popad Mar 02, 2022 11:06 AM
8 Attachment(s)
Working ... while waiting to dry, glue other pieces.
#10 popad Mar 02, 2022 03:01 PM
4 Attachment(s)
Little steps ...
#11 popad Mar 03, 2022 09:48 AM
30 Attachment(s)
My box is starting to take shape. I'm getting to the end. A little more :).
Some little change to fix more well the fuselage.
#12 popad Mar 03, 2022 01:18 PM
6 Attachment(s)
All reinforcements glued in right place ... Next, sanding, aplly cover foil, fittings, screws, etc.
#13 popad Mar 04, 2022 06:48 AM
14 Attachment(s)
Ok. today I have finished this project !
All fittings, screw fit perfectly. A nice kit ! Wonderful box for Introduction or Inside F5J.
#14 popad Mar 05, 2022 02:25 AM
7 Attachment(s)
And last pictures from this project ...
#15 lucdus Mar 06, 2022 02:56 AM
Thanks for the infos and photos, sounds great . I plan to order one too - Regards
